Djinn5150's SmartRap Core Build March 01, 2015 11:11AM |
Re: Djinn5150's SmartRap Core Build March 01, 2015 12:46PM |
Re: Djinn5150's SmartRap Core Build March 01, 2015 12:58PM |
Re: Djinn5150's SmartRap Core Build March 01, 2015 01:46PM |
Re: Djinn5150's SmartRap Core Build March 01, 2015 02:20PM |
Re: Djinn5150's SmartRap Core Build March 01, 2015 03:51PM |
Re: Djinn5150's SmartRap Core Build March 01, 2015 04:13PM |
Re: Djinn5150's SmartRap Core Build March 01, 2015 04:29PM |
A few things you should know if you havent been following the youmagine comments.|
Re: Djinn5150's SmartRap Core Build March 01, 2015 10:20PM |
Re: Djinn5150's SmartRap Core Build March 02, 2015 12:51PM |
Re: Djinn5150's SmartRap Core Build March 02, 2015 01:25PM |
Re: Djinn5150's SmartRap Core Build March 02, 2015 03:31PM |
Re: Djinn5150's SmartRap Core Build March 02, 2015 05:10PM |
Re: Djinn5150's SmartRap Core Build March 02, 2015 05:11PM |
Re: Djinn5150's SmartRap Core Build March 02, 2015 10:56PM |
I am super excited about this build, Just got my 18x8 proximity sensor in today, did a lil testing. It picks up the heated bed through glass @ 5v. Sweet|
Re: Djinn5150's SmartRap Core Build March 04, 2015 01:25PM |
Re: Djinn5150's SmartRap Core Build March 04, 2015 04:40PM |
good job. I want to try that for such long time ... i've never had time to do. but now.. i can try at last.
so i use a resistor bridge now at 12v.. it works perfectly.|
Re: Djinn5150's SmartRap Core Build March 04, 2015 08:10PM |
CptanPanic
Can you post link to inductive sensor you got?
Re: Djinn5150's SmartRap Core Build March 04, 2015 08:49PM |
Re: Djinn5150's SmartRap Core Build March 05, 2015 01:23AM |
cristian
What is the precision of these sensors in microns?
Re: Djinn5150's SmartRap Core Build March 05, 2015 06:54AM |
Re: Djinn5150's SmartRap Core Build March 05, 2015 10:55AM |
cristian
djinn5150
unfortunately I have no dial gauge and I have yet to run any repeated probes to check for variances.
When you manage to run the probes, if you post the results I will be very thankful.
07:26:48.787 : N360624 G28 X0 Y0 *7 07:26:48.787 : N360625 G1 X100 Y95 F3000 *101 07:26:48.787 : N360626 G1 Z5 *112 07:26:48.787 : N360627 G30 *12 07:26:48.787 : N360628 G92 Z0 *65 07:26:51.990 : N360629 G1 Z5 *127 07:26:51.990 : N360630 G30 *10 07:26:51.990 : N360631 G1 Z5 *118 07:26:51.990 : N360632 G30 *8 07:26:59.888 : Bed X: 100.00 Y: 95.00 Z: 0.01 07:26:59.888 : echo:endstops hit: Z:0.01 07:26:59.888 : N360633 G1 Z5 *116 07:26:59.888 : N360634 G30 *14 07:26:59.888 : N360635 G1 Z5 *114 07:26:59.888 : N360636 G30 *12 07:27:04.951 : Bed X: 100.00 Y: 95.00 Z: 0.00 07:27:04.951 : echo:endstops hit: Z:0.00 07:27:04.951 : N360637 G1 Z5 *112 07:27:04.951 : N360638 G30 *2 07:27:09.995 : Bed X: 100.00 Y: 95.00 Z: 0.00 07:27:09.995 : echo:endstops hit: Z:0.00 07:27:09.995 : N360639 G1 Z5 *126 07:27:09.995 : N360640 G30 *13 07:27:15.010 : Bed X: 100.00 Y: 95.00 Z: 0.00 07:27:15.010 : echo:endstops hit: Z:0.00 07:27:15.104 : N360641 G1 Z5 F500 *34 07:27:20.120 : Bed X: 100.00 Y: 95.00 Z: 0.00 07:27:20.135 : N360642 G30 *15 07:27:20.135 : echo:endstops hit: Z:0.00 07:27:20.135 : N360643 G1 Z5 *115 07:27:25.181 : Bed X: 100.00 Y: 95.00 Z: -0.02 07:27:25.181 : echo:endstops hit: Z:-0.02 07:27:25.181 : N360644 G30 *9 07:27:25.181 : N360645 G1 Z5 *117 07:27:30.313 : Bed X: 100.00 Y: 95.00 Z: -0.00 07:27:30.313 : N360646 G30 *11 07:27:30.313 : echo:endstops hit: Z:-0.00 07:27:30.313 : N360647 G1 Z5 *119 07:27:30.313 : N360648 G30 *5 07:27:35.422 : Bed X: 100.00 Y: 95.00 Z: -0.02 07:27:35.438 : echo:endstops hit: Z:-0.02 07:27:35.438 : N360649 G1 Z5 *121 07:27:35.438 : N360650 G30 *12 07:27:40.547 : Bed X: 100.00 Y: 95.00 Z: -0.01 07:27:40.547 : echo:endstops hit: Z:-0.00 07:27:40.641 : N360651 G1 Z5 *112 07:27:40.641 : N360652 G30 *14 07:27:45.672 : Bed X: 100.00 Y: 95.00 Z: -0.00 07:27:45.672 : echo:endstops hit: Z:-0.00 07:27:50.704 : Bed X: 100.00 Y: 95.00 Z: -0.00 07:27:50.704 : echo:endstops hit: Z:-0.00 07:27:55.737 : Bed X: 100.00 Y: 95.00 Z: -0.00 07:27:55.737 : echo:endstops hit: Z:-0.00 07:28:00.831 : Bed X: 100.00 Y: 95.00 Z: -0.00 07:28:00.831 : echo:endstops hit: Z:-0.00
Re: Djinn5150's SmartRap Core Build March 05, 2015 11:04AM |
Thanks for giving me the motivation to figure it out finally, I never realized how simple it is. As it sits now the code is pretty messy and static, I will be working on cleaning it up this afternoon and going parametric to allow the end user to choose between fan size, sensor size, and hot-end mount size. I am also trying to find a place to add "cooling" fans for the parts but may be down the line. |
Re: Djinn5150's SmartRap Core Build March 05, 2015 11:16AM |
djinn5150
My estimate is +/- 200 microns
Re: Djinn5150's SmartRap Core Build March 05, 2015 11:30AM |
cristian
djinn5150
Many thanks.
Am I wrong or it is +/- 20 microns (instead of 200) ?
200 is bad (about as much as the average layer height), on the other hand 20 microns is definitely more than acceptable.
Re: Djinn5150's SmartRap Core Build March 05, 2015 11:50AM |
Re: Djinn5150's SmartRap Core Build March 05, 2015 01:43PM |
Re: Djinn5150's SmartRap Core Build March 05, 2015 03:21PM |
Re: Djinn5150's SmartRap Core Build March 05, 2015 05:32PM |
Re: Djinn5150's SmartRap Core Build March 06, 2015 06:48PM |
