Re: mandrav's SmartCore build September 18, 2015 09:59AM |
Re: mandrav's SmartCore build September 18, 2015 12:40PM |
Re: mandrav's SmartCore build September 18, 2015 03:16PM |
Re: mandrav's SmartCore build September 18, 2015 03:17PM |
Re: mandrav's SmartCore build September 21, 2015 11:26AM |
Re: mandrav's SmartCore build September 22, 2015 03:54AM |
Re: mandrav's SmartCore build December 07, 2015 03:20AM |
Re: mandrav's SmartCore build February 05, 2016 01:53PM |
mandrav
Both bushing types you linked should work just fine.
For using them you have two options:
a) edit the jscad file to change the hole dimensions for 'head' and 'slide_y' so that the bushings you choose fit, or
b) you can search thingiverse for 'bushing adapter'. With these you will fit your bushings inside the adapter and use the adapter in place of the lm8uu/lm6uu you would otherwise use.
I finally went with option (a). But I first had tried option (b) and that didn't go too well for me... YMMV...
HTH.
