LCD full graphic reprapdiscount schermo blu February 13, 2016 11:37AM |
#include #ifndef CONFIGURATION_H #define CONFIGURATION_H // This configuration file contains basic settings. Select your: // - board type // - Mechanism type (cartesian-corexy-delta-scara) // - temperature sensor type // // Mechanisms-settings can be found in configuration_xxxxxx.h // Advanced settings can be found in Configuration_adv.h #include "boards.h" // Choose your board type. // Either an numeric ID or name defined in boards.h is valid. // See: [github.com] #define MOTHERBOARD BOARD_RAMPS_13_HFB // User-specified version info of this build to display in [Pronterface, etc] terminal window during // startup. Implementation of an idea by Prof Braino to inform user that any changes made to this // build by the user have been successfully uploaded into firmware. #define STRING_VERSION "4.1.2" #define STRING_URL "reprap.org" #define STRING_VERSION_CONFIG_H __DATE__ " " __TIME__ // build date and time #define STRING_CONFIG_H_AUTHOR "(none, default config)" // Who made the changes. #define STRING_SPLASH_LINE1 "v" STRING_VERSION // will be shown during bootup in line 1 #define STRING_SPLASH_LINE2 STRING_VERSION_CONFIG_H // will be shown during bootup in line 2 // SERIAL PORT selects which serial port should be used for communication with the host. // This allows the connection of wireless adapters (for instance) to non-default port pins. // Serial port 0 is still used by the Arduino bootloader regardless of this setting. #define SERIAL_PORT 0 // This determines the communication speed of the printer // 115200 - 250000 #define BAUDRATE 250000 // This enables the serial port associated to the Bluetooth interface on AT90USB devices //#define BTENABLED // Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines) // You can use an online service to generate a random UUID. (eg [www.uuidgenerator.net]) //#define MACHINE_UUID "00000000-0000-0000-0000-000000000000" // If you want test the firmware uncomment below. Use Serial arduino monitor... //#define FIRMWARE_TEST // ONLY BAUDRATE 115200 //=========================================================================== //============================ User Interfaces ============================== //=========================================================================== //==============================LCD and SD support============================= // Choose ONE of these 3 charsets. This has to match your hardware. Ignored for full graphic display. // To find out what type you have - compile with (test) - upload - click to get the menu. You'll see two typical lines from the upper half of the charset. // See also documentation/LCDLanguageFont.md #define DISPLAY_CHARSET_HD44780_JAPAN // this is the most common hardware //#define DISPLAY_CHARSET_HD44780_WESTERN //#define DISPLAY_CHARSET_HD44780_CYRILLIC //#define ULTRA_LCD //general LCD support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) #define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication //#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder //#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking //#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store. //#define ULTIPANEL //the UltiPanel as on Thingiverse //#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click //#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click // 0 to disable buzzer feedback. Test with M300 S P // PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3) // [reprap.org] //#define PANEL_ONE // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The Panucatt Devices Viki 2.0 and mini Viki with Graphic LCD // [panucatt.com] // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] //#define VIKI2 //#define miniVIKI // The RepRapDiscount Smart Controller (white PC // [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC // [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC // [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] #define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER // The RepRapWorld REPRAPWORLD_KEYPAD v1.1 // [reprapworld.com] //#define REPRAPWORLD_KEYPAD //#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click // The Elefu RA Board Control Panel // [www.elefu.com] // REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARDUINO library folder: [github.com] //#define RA_CONTROL_PANEL // I2C Panels //#define LCD_I2C_SAINSMART_YWROBOT // PANELOLU2 LCD with status LEDs, separate encoder and click inputs //#define LCD_I2C_PANELOLU2 // Panucatt VIKI LCD with status LEDs, integrated click & L/R/U/P buttons, separate encoder inputs //#define LCD_I2C_VIKI // Shift register panels // --------------------- // 2 wire Non-latching LCD SR from: // [bitbucket.org] //#define SAV_3DLCD // option for invert rotary switch //#define INVERT_ROTARY_SWITCH // Uncomment screen orientation ONLY FOR GRAPHICS DISPLAY #define LCD_SCREEN_ROT_0 // #define LCD_SCREEN_ROT_90 // #define LCD_SCREEN_ROT_180 // #define LCD_SCREEN_ROT_270 // SPLASH SCREEN duration in millisecond #define SPLASH_SCREEN_DURATION 2000 // Millisecond /** Display Voltage Logic Selector on Alligator Board 0 = Voltage level 3.3V 1 = Voltage level 5V */ #define UI_VOLTAGE_LEVEL 0 // Set 5 o 3.3 V
Re: LCD full graphic reprapdiscount schermo blu February 21, 2016 02:09PM |
Re: LCD full graphic reprapdiscount schermo blu February 23, 2016 03:03AM |
Re: LCD full graphic reprapdiscount schermo blu March 27, 2016 06:47PM |
Re: LCD full graphic reprapdiscount schermo blu April 11, 2016 11:00AM |
Re: LCD full graphic reprapdiscount schermo blu May 02, 2016 01:05PM |
Re: LCD full graphic reprapdiscount schermo blu March 09, 2018 02:05AM |
