Problemi con la temperatura November 12, 2019 03:22PM |
Re: Problemi con la temperatura November 12, 2019 03:32PM |
Re: Problemi con la temperatura November 12, 2019 03:37PM |
Re: Problemi con la temperatura November 12, 2019 03:51PM |
Re: Problemi con la temperatura November 12, 2019 03:55PM |
Re: Problemi con la temperatura November 13, 2019 02:51AM |
* M305 - Set thermistor and ADC parameters. * H[heaters] 0-5 Hotend, -1 BED, -2 CHAMBER, -3 COOLER * T[int] 0-3 For Select Beds or Chambers (default 0) * A[float] Thermistor resistance at 25°C, B[float] BetaK, C[float] Steinhart-Hart C coefficien, R[float] Pullup resistor value, * L[int] ADC low offset correction, O[int] ADC high offset correction, P[int] Sensor Pin * Set DHT sensor parameter: D0 P[int] Sensor Pin, S[int] Sensor Type (11, 21, 22).
Re: Problemi con la temperatura November 13, 2019 03:55PM |
Re: Problemi con la temperatura November 14, 2019 02:24AM |
