Finalmente terminato....Revamping Prusa I3, ma.... December 26, 2015 11:06AM |
// Mechanical endstop with COM to ground and NC to Signal uses "false" here (most common setup). #define X_MIN_ENDSTOP_LOGIC true // set to true to invert the logic of the endstop. #define Y_MIN_ENDSTOP_LOGIC true // set to true to invert the logic of the endstop. #define Z_MIN_ENDSTOP_LOGIC true // set to true to invert the logic of the endstop. #define E_MIN_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. #define X_MAX_ENDSTOP_LOGIC true // set to true to invert the logic of the endstop. #define Y_MAX_ENDSTOP_LOGIC true // set to true to invert the logic of the endstop. #define Z_MAX_ENDSTOP_LOGIC true // set to true to invert the logic of the endstop. #define Z_PROBE_ENDSTOP_LOGIC false // set to true to invert the logic of the endstop. // ENDSTOP SETTINGS: // Sets direction of endstop when homing; 1=MAX, -1=MIN #define X_HOME_DIR -1 #define Y_HOME_DIR -1 #define Z_HOME_DIR -1 #define E_HOME_DIR -1 #define min_software_endstops true // If true, axis won't move to coordinates less than HOME_POS. #define max_software_endstops true // If true, axis won't move to coordinates greater than the defined lengths below. // For Inverting Stepper Enable Pins (Active Low) use 0, Non Inverting (Active High) use 1 #define X_ENABLE_ON 0 #define Y_ENABLE_ON 0 #define Z_ENABLE_ON 0 #define E_ENABLE_ON 0 // For all extruder // Disables axis when it's not being used. #define DISABLE_X false #define DISABLE_Y false #define DISABLE_Z false #define DISABLE_E false // For all extruder #define DISABLE_INACTIVE_EXTRUDER false //disable only inactive extruder and keep active extruder enabled // Invert the stepper direction. Change (or reverse the motor connector) if an axis goes the wrong way. #define INVERT_X_DIR true #define INVERT_Y_DIR true #define INVERT_Z_DIR true #define INVERT_E0_DIR true #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false
Re: Finalmente terminato....Revamping Prusa I3, ma.... December 26, 2015 05:57PM |
