Regolazione assi con viti a ricircolo December 13, 2014 09:14AM |
// default settings #define DEFAULT_AXIS_STEPS_PER_UNIT {200,200,3200,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit #define DEFAULT_MAX_FEEDRATE {300,300,2,100,100,100,100} // X, Y, Z, E0, E1, E2, E3 (mm/sec) #define DEFAULT_RETRACTION_MAX_FEEDRATE {110,110,110,110} // E0, E1, E2, E3 (mm/sec) #define DEFAULT_MAX_ACCELERATION {500,500,50,500} // X, Y, Z, E maximum start speed for accelerated moves. #define DEFAULT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 500 // X, Y, Z and E max acceleration in mm/s^2 for retracts
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:25AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:38AM |
#define DEFAULT_AXIS_STEPS_PER_UNIT {100,100,3200,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:44AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 09:53AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:01AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:19AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:24AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:32AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:33AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 10:37AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 11:12AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 11:14AM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 01:52PM |
#define HOMING_FEEDRATE {20*60, 20*60, 4*60, 0} // set the homing speeds (mm/min)
#define DEFAULT_AXIS_STEPS_PER_UNIT {640,640,640,625,625,625,625} // X, Y, Z, E0, E1, E2, E3 default steps per unit
#define X_MAX_POS 340 #define X_MIN_POS 0 #define Y_MAX_POS 340 #define Y_MIN_POS 0 #define Z_MAX_POS 340 #define Z_MIN_POS 0
Re: Regolazione assi con viti a ricircolo December 13, 2014 02:18PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 02:56PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 03:21PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 05:33PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 06:00PM |
Re: Regolazione assi con viti a ricircolo December 13, 2014 06:26PM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 06:40AM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 07:14AM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 09:40AM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 09:52AM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 03:45PM |
Re: Regolazione assi con viti a ricircolo December 14, 2014 06:29PM |
Re: Regolazione assi con viti a ricircolo February 12, 2015 08:11AM |
Re: Regolazione assi con viti a ricircolo February 14, 2015 03:46PM |
