Re: piccolo_3d 32bit board arduino due April 21, 2017 09:46AM |
---- Progetto "Work in progress" CoreXY 3D printer Meccanica OpenBuild su barre V-Slot, piano magnetico riscaldato 300x200, RuRamps4D v1.3 con TMC2130 in SPI e Nextion 7, Estrusore E3Dv6 a 3 colori. Ovviamente latest MK4Duo 4.3.x" ---- Prossimamente su Thingiverse |
Re: piccolo_3d 32bit board arduino due April 21, 2017 11:18AM |
Re: piccolo_3d 32bit board arduino due April 21, 2017 12:57PM |
Re: piccolo_3d 32bit board arduino due April 22, 2017 02:04PM |
Re: piccolo_3d 32bit board arduino due April 23, 2017 02:21AM |
Re: piccolo_3d 32bit board arduino due April 23, 2017 02:50AM |
#define TEMP_TIMER_FREQUENCY ((F_CPU) / 64.0 / 64.0) // 3096 HzE le ultime due // sono commento vuol dire che fa 3096 hz, infatti sono 16000000 / 64 / 64 = 3906,25...
#define TEMP_TIMER_FREQUENCY 3906
Re: piccolo_3d 32bit board arduino due April 23, 2017 03:19AM |
Re: piccolo_3d 32bit board arduino due April 23, 2017 11:40AM |
Re: piccolo_3d 32bit board arduino due April 24, 2017 04:17AM |
Re: piccolo_3d 32bit board arduino due April 24, 2017 11:42AM |
--- Prusa i3 Steel (20x20x20) --- Prusa i3 Steel XL (30x30x30)
Motori 200 passi Motori 400 passi
Stepper drive - DRV8825 Stepper drive - DRV8825
RAMPS 1.4 RADDS 1.5
HotEnd IeC HotEnd IeC
FW MK4DUO 4.3.2 FW MK4DUO 4.3.5
Re: piccolo_3d 32bit board arduino due April 24, 2017 05:39PM |
Re: piccolo_3d 32bit board arduino due April 25, 2017 02:30AM |
Re: piccolo_3d 32bit board arduino due April 25, 2017 02:42AM |
Re: piccolo_3d 32bit board arduino due April 25, 2017 11:32AM |
Re: piccolo_3d 32bit board arduino due April 25, 2017 03:30PM |
Re: piccolo_3d 32bit board arduino due April 26, 2017 07:08AM |
Re: piccolo_3d 32bit board arduino due April 26, 2017 08:38AM |
Re: piccolo_3d 32bit board arduino due April 26, 2017 09:15AM |
Re: piccolo_3d 32bit board arduino due May 03, 2017 01:49AM |
Re: piccolo_3d 32bit board arduino due May 03, 2017 04:21AM |
Re: piccolo_3d 32bit board arduino due May 03, 2017 08:26AM |
rosario3dprt
Beh, direi che il primo che hai provato è decisamente fuori dai parametri costruttivi.
Se gli ultimi arrivati funzionano correttamente mi sembra rimanga solo da cestinare quelli del negozio italiano.
Re: piccolo_3d 32bit board arduino due May 03, 2017 08:34AM |
Re: piccolo_3d 32bit board arduino due May 09, 2017 11:38PM |
Re: piccolo_3d 32bit board arduino due May 10, 2017 03:46AM |
Re: piccolo_3d 32bit board arduino due May 10, 2017 04:12AM |
Re: piccolo_3d 32bit board arduino due May 11, 2017 10:10AM |
Re: piccolo_3d 32bit board arduino due May 12, 2017 01:25AM |
Re: piccolo_3d 32bit board arduino due May 12, 2017 08:45AM |
Re: piccolo_3d 32bit board arduino due May 12, 2017 08:54AM |
MagoKimbra
Bellissima scheda... Bravo...
Bene installata su arduino due scaricato il fw ed ha subito funzionato:
[attachment 94059 18422113_1925036954441653_3502190896260654812_o.jpg]
Provato accensione Hotend con lampadina led a 12v, stessa cosa il bed e fan. Alimentatore ATX perfetto.. Ora mi servono i driver e i cavetti a tre poli per connettere la scheda driver...
Domanda il modulo come funziona? Ho letto che hai scritto che è sulla seriale 1, ma va attivato da qualche parte?
Prossima settimana faccio i test anche del display sia normali che nextion.. Per ora tutto OK!!
Re: piccolo_3d 32bit board arduino due May 12, 2017 11:25AM |
