Re: piccolo_3d 32bit board arduino due September 19, 2017 06:11AM |
--- Prusa i3 Steel (20x20x20) --- Prusa i3 Steel XL (30x30x30)
Motori 200 passi Motori 400 passi
Stepper drive - DRV8825 Stepper drive - DRV8825
RAMPS 1.4 RADDS 1.5
HotEnd IeC HotEnd IeC
FW MK4DUO 4.3.2 FW MK4DUO 4.3.5
Re: piccolo_3d 32bit board arduino due September 19, 2017 06:52AM |
Re: piccolo_3d 32bit board arduino due September 19, 2017 10:54AM |
c128
il modulo ESP e' collegato sulla seriale1
altra seriale disponibile e' la 2 ma per usi esterni come in nextion lcd
RAMPS 1.4 RADDS 1.5
Re: piccolo_3d 32bit board arduino due September 24, 2017 03:27AM |
Re: piccolo_3d 32bit board arduino due September 24, 2017 03:47PM |
#include
void setup(void)
Serial.begin(115200);
Wire.begin();
writeEEPROM(0, 123);
Serial.print(readEEPROM(0), DEC);
void loop(){}
void writeEEPROM(unsigned int eeaddress, byte data)
Wire.beginTransmission(0x50);
Wire.write((int)(eeaddress >> 8)); // MSB
Wire.write((int)(eeaddress & 0xFF)); // LSB
Wire.write(data);
Wire.endTransmission();
delay(6);
byte readEEPROM(unsigned int eeaddress)
byte rdata = 0xFF;
Wire.requestFrom(0x50, 1);
if (Wire.available()) rdata = Wire.read();
return rdata;
Re: piccolo_3d 32bit board arduino due September 29, 2017 09:31AM |
Re: piccolo_3d 32bit board arduino due September 30, 2017 04:38PM |
Re: piccolo_3d 32bit board arduino due September 30, 2017 07:19PM |
c128
per il Nextion basta usare la seriale2 mentre per il modulo SD esterno non e' previsto ma e' facilmente implementabile anche se aumenterebbe un po la complessita' della scheda come numero di connettori
Re: piccolo_3d 32bit board arduino due October 01, 2017 01:45AM |
Re: piccolo_3d 32bit board arduino due October 08, 2017 06:38AM |
Re: piccolo_3d 32bit board arduino due October 08, 2017 01:50PM |
Re: piccolo_3d 32bit board arduino due October 08, 2017 03:17PM |
Re: piccolo_3d 32bit board arduino due October 08, 2017 04:26PM |
Re: piccolo_3d 32bit board arduino due October 12, 2017 10:38AM |
Re: piccolo_3d 32bit board arduino due October 13, 2017 03:20AM |
Re: piccolo_3d 32bit board arduino due October 13, 2017 01:10PM |
Re: piccolo_3d 32bit board arduino due October 13, 2017 02:21PM |
Re: piccolo_3d 32bit board arduino due November 24, 2017 02:47AM |
| ---- Progetto "Work in progress" CoreXY 3D printer Meccanica OpenBuild su barre V-Slot, piano magnetico riscaldato 300x200, RuRamps4D v1.3 con TMC2130 in SPI e Nextion 7, Estrusore E3Dv6 a 3 colori. Ovviamente latest MK4Duo 4.3.x" ---- Prossimamente su Thingiverse |
Re: piccolo_3d 32bit board arduino due November 24, 2017 07:13AM |
Re: piccolo_3d 32bit board arduino due November 24, 2017 07:37AM |
Re: piccolo_3d 32bit board arduino due November 24, 2017 08:07AM |
#if ENABLED(ARDUINO_ARCH_SAM) && !MB(RADDS) current_temperature_mcu_raw = HAL::AnalogInputValues[MCU_SENSOR_INDEX]; #endif
Re: piccolo_3d 32bit board arduino due November 24, 2017 08:13AM |
Re: piccolo_3d 32bit board arduino due November 25, 2017 08:37AM |
Re: piccolo_3d 32bit board arduino due November 25, 2017 09:30AM |
Re: piccolo_3d 32bit board arduino due November 25, 2017 11:19AM |
Re: piccolo_3d 32bit board arduino due November 26, 2017 11:10AM |
rosario3dprt
Mago,
con la versione scaricata stamane il PWM13 funziona correttamente senza ulteriori modifiche.
Non so era questa che intendevi come ultima versione in rilascio.
Re: piccolo_3d 32bit board arduino due November 27, 2017 03:56AM |
Re: piccolo_3d 32bit board arduino due November 27, 2017 07:13AM |
Re: piccolo_3d 32bit board arduino due November 27, 2017 07:50AM |
Re: piccolo_3d 32bit board arduino due December 04, 2017 02:06PM |
