Re: auto bed leveling e marlin Risolto May 07, 2014 12:42PM |
#define Z_PROBE_OFFSET_FROM_EXTRUDER -5 #define Z_RAISE_BEFORE_HOMING 4
#define Z_RAISE_BEFORE_HOMING 15
Re: auto bed leveling e marlin Risolto May 07, 2014 04:53PM |
Moderator Registered: 12 years ago Posts: 964 |
Re: auto bed leveling e marlin [Parzialmente Risolto] May 09, 2014 01:33PM |
#define ENABLE_AUTO_BED_LEVELING // Delete the comment to enable (remove // at the start of the line) #ifdef ENABLE_AUTO_BED_LEVELING // There are 2 different ways to pick the X and Y locations to probe: // - "grid" mode // Probe every point in a rectangular grid // You must specify the rectangle, and the density of sample points // This mode is preferred because there are more measurements. // It used to be called ACCURATE_BED_LEVELING but "grid" is more descriptive // - "3-point" mode // Probe 3 arbitrary points on the bed (that aren't colinear) // You must specify the X & Y coordinates of all 3 points #define AUTO_BED_LEVELING_GRID // with AUTO_BED_LEVELING_GRID, the bed is sampled in a // AUTO_BED_LEVELING_GRID_POINTSxAUTO_BED_LEVELING_GRID_POINTS grid // and least squares solution is calculated // Note: this feature occupies 10'206 byte #ifdef AUTO_BED_LEVELING_GRID // set the rectangle in which to probe #define LEFT_PROBE_BED_POSITION 100 #define RIGHT_PROBE_BED_POSITION 170 #define BACK_PROBE_BED_POSITION 180 #define FRONT_PROBE_BED_POSITION 100 // set the number of grid points per dimension // I wouldn't see a reason to go above 3 (=9 probing points on the bed) #define AUTO_BED_LEVELING_GRID_POINTS 3 #else // not AUTO_BED_LEVELING_GRID // with no grid, just probe 3 arbitrary points. A simple cross-product // is used to esimate the plane of the print bed #define ABL_PROBE_PT_1_X 15 #define ABL_PROBE_PT_1_Y 180 #define ABL_PROBE_PT_2_X 15 #define ABL_PROBE_PT_2_Y 20 #define ABL_PROBE_PT_3_X 170 #define ABL_PROBE_PT_3_Y 20 #endif // AUTO_BED_LEVELING_GRID // these are the offsets to the probe relative to the extruder tip (Hotend - Probe) #define X_PROBE_OFFSET_FROM_EXTRUDER 0 #define Y_PROBE_OFFSET_FROM_EXTRUDER 0 #define Z_PROBE_OFFSET_FROM_EXTRUDER 0 #define Z_RAISE_BEFORE_HOMING 10 // (in mm) Raise Z before homing (G28) for Probe Clearance. // Be sure you have this distance over your Z_MAX_POS in case #define XY_TRAVEL_SPEED 8000 // X and Y axis travel speed between probes, in mm/min #define Z_RAISE_BEFORE_PROBING 15 //How much the extruder will be raised before traveling to the first probing point. #define Z_RAISE_BETWEEN_PROBINGS 15 //How much the extruder will be raised when traveling from between next probing points
Re: auto bed leveling e marlin [Parzialmente Risolto] May 09, 2014 01:42PM |
Re: auto bed leveling e marlin [Parzialmente Risolto] May 13, 2014 07:22AM |
13:11:38.060 : Segnalazione stato degli endstop 13:11:38.060 : x_min: aperto 13:11:38.064 : x_max: INNESCATO 13:11:38.064 : y_min: INNESCATO 13:11:38.064 : y_max: aperto 13:11:38.068 : z_min: aperto 13:11:38.069 : z_max: INNESCATO
13:11:06.508 : Piatto x: 15.00 y: 180.00 z: -2.15 13:11:07.497 : Piatto x: 15.00 y: 20.00 z: -3.24 13:11:08.526 : Piatto x: 170.00 y: 20.00 z: -4.35 13:11:09.534 : echo:Raggiunto il fondo carrello: X:15.00 Y:180.00 Z:-4.35
Re: auto bed leveling e marlin [Parzialmente Risolto] May 13, 2014 07:36AM |
Re: auto bed leveling e marlin [Parzialmente Risolto] May 13, 2014 09:27AM |
Re: auto bed leveling e marlin [Parzialmente Risolto] May 13, 2014 09:52AM |
Re: auto bed leveling e marlin [Parzialmente Risolto] May 18, 2014 01:47PM |
Re: auto bed leveling e marlin [Parzialmente Risolto] May 18, 2014 02:06PM |
Re: auto bed leveling e marlin [Parzialmente Risolto] May 28, 2014 09:34AM |
Re: auto bed leveling e marlin Risolto January 27, 2015 08:04PM |
MagoKimbra
cioè hai solo quello sul servo giusto?
// #define PROBE_SERVO_DEACTIVATION_DELAY 300
Togli le barrette su questa linea.
e metti 15 invece che 40, ho appena provato e anche a me con 40 non sale forse c'è un limite.. con 15 va però!!!
Re: auto bed leveling e marlin Risolto January 28, 2015 03:19AM |
Re: auto bed leveling e marlin Risolto January 28, 2015 05:31AM |
MagoKimbra
Lo schema va bene...
Lo switch uno qualsiasi, io gli ho tolto la linguetta, faccio toccare direttamente il pulsantino sul bed.
Il servo va bene, meglio con gli ingranaggi in metallo durano di più, sono più lenti, ma più potenti..
