Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 09:24AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 09:35AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 09:46AM |
const int sensitive_pins[] = SENSITIVE_PINS; // Sensitive pin list for M42
// This defines the number of extruders
#ifdef REPRAPPRO_MULTIMATERIALS
#define EXTRUDERS 3
#else
#define EXTRUDERS 3
#endif
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 09:56AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 09:58AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:01AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:05AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:09AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:16AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:17AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:23AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:30AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:45AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:52AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 10:54AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN October 21, 2014 11:15AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 03:43PM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 04:06PM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 04:27PM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 21, 2014 06:44PM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 02:28AM |
#ifdef REPRAPPRO_MULTIMATERIALS SERIAL_PROTOCOLPGM("ok"); for(int e = 0; e < EXTRUDERS; e++) { SERIAL_PROTOCOLPGM(" T"); SERIAL_PROTOCOL(e); SERIAL_PROTOCOLPGM(": "); SERIAL_PROTOCOL_F(degHotend(e),1); SERIAL_PROTOCOLPGM("/"); SERIAL_PROTOCOL_F(degTargetHotend(e),1); } #if TEMP_BED_PIN > -1 SERIAL_PROTOCOLPGM(" B:"); SERIAL_PROTOCOL_F(degBed(),1); SERIAL_PROTOCOLPGM(" /"); SERIAL_PROTOCOL_F(degTargetBed(),1); #endif //TEMP_BED_PIN #ifdef PIDTEMP SERIAL_PROTOCOLPGM(" @:"); SERIAL_PROTOCOL(getHeaterPower(tmp_extruder)); #endif SERIAL_PROTOCOLLN(""); #else
T:22.7 /0.0 B:22.8 /0.0 T0:22.7 /0.0 T1:22.7 /0.0 T2:22.7 /0.0 @:0 B@:0
T0: 25.1/-273.1 T1: 24.7/-273.1 T2: 25.0/-273.1 B:27.2 /-273.1 @:0
#if TEMP_BED_PIN > -1 SERIAL_PROTOCOLPGM(" B:"); SERIAL_PROTOCOL_F(degBed(),1); SERIAL_PROTOCOLPGM(" /"); SERIAL_PROTOCOL_F(degTargetBed(),1); #endif //TEMP_BED_PINE da qui la sequenza che la scheda dava : T0: 25.1/-273.1 T1: 24.7/-273.1 T2: 25.0/-273.1 B:27.2 /-273.1 @:0
#ifdef REPRAPPRO_MULTIMATERIALS SERIAL_PROTOCOLPGM("ok T:"); SERIAL_PROTOCOL_F(degHotend(0),1); SERIAL_PROTOCOLPGM(" /"); SERIAL_PROTOCOL_F(degTargetHotend(0),1); #if defined(TEMP_BED_PIN) && TEMP_BED_PIN > -1 SERIAL_PROTOCOLPGM(" B:"); SERIAL_PROTOCOL_F(degBed(),1); SERIAL_PROTOCOLPGM(" /"); SERIAL_PROTOCOL_F(degTargetBed(),1); #endif //TEMP_BED_PIN for(int e = 0; e < EXTRUDERS; e++) { SERIAL_PROTOCOLPGM(" T"); SERIAL_PROTOCOL(e); SERIAL_PROTOCOLPGM(":"); SERIAL_PROTOCOL_F(degHotend(e),1); SERIAL_PROTOCOLPGM(" /"); SERIAL_PROTOCOL_F(degTargetHotend(e),1); } #ifdef PIDTEMP SERIAL_PROTOCOLPGM(" @:"); SERIAL_PROTOCOL(getHeaterPower(tmp_extruder)); #endif SERIAL_PROTOCOLLN(""); #else
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 03:01AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 03:27AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 05:15AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 08:45AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 08:54AM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 02:12PM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 02:36PM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 03:43PM |
Re: REPETIER HOST( V 1 TO 1.4 ) PROBLEMI CON MARLIN ( PROBLEM SOLVED ) October 22, 2014 03:48PM |
