Re: MarlinKimbra 4.2.x September 11, 2015 05:53AM |
Re: MarlinKimbra 4.2.x September 13, 2015 05:55PM |
Re: MarlinKimbra 4.2.x September 13, 2015 06:04PM |
Re: MarlinKimbra 4.2.x September 13, 2015 06:33PM |
e bed levelling non funzionanoQuote
********************************** Stepper direction ************************************
* Invert the stepper direction. *
* Change (or reverse the motor connector) if an axis goes the wrong way. *
#define INVERT_X_DIR false
#define INVERT_Y_DIR false
#define INVERT_Z_DIR false
#define INVERT_E0_DIR treu
#define INVERT_E1_DIR true
#define INVERT_E2_DIR true
#define INVERT_E3_DIR true
************************************* Disables axis *************************************
* Disables axis when it's not being used. *
#define DISABLE_X false
#define DISABLE_Y false
#define DISABLE_Z true
#define DISABLE_E false // For all extruder
// Disable only inactive extruder and keep active extruder enabled
#define DISABLE_INACTIVE_EXTRUDER true
ultralcd.cpp: In function 'void lcd_tune_menu()':
ultralcd.cpp:547: error: 'LCD_MAX_TEMP_OFFSET' was not declared in this scope
MENU_MULTIPLIER_ITEM_EDIT(int3, MSG_NOZZLE " 0", &target_temperature[0], 0, HEATER_0_MAXTEMP + LCD_MAX_TEMP_OFFSET);
ultralcd.cpp:220:32: note: in definition of macro 'MENU_MULTIPLIER_ITEM'
menu_action_ ## type(args); \
ultralcd.cpp:547:5: note: in expansion of macro 'MENU_MULTIPLIER_ITEM_EDIT'
ultralcd.cpp: In function 'void lcd_prepare_temperature_menu()':
ultralcd.cpp:843: error: 'LCD_MAX_TEMP_OFFSET' was not declared in this scope
ultralcd.cpp:843:5: note: in expansion of macro 'MENU_MULTIPLIER_ITEM_EDIT'
ultralcd.cpp: In function 'void lcd_control_temperature_menu()':
ultralcd.cpp:1101: error: 'LCD_MAX_TEMP_OFFSET' was not declared in this scope
MENU_ITEM_EDIT(float3, MSG_MIN, &autotemp_min, 0, HEATER_0_MAXTEMP + LCD_MAX_TEMP_OFFSET);
ultralcd.cpp:197:30: note: in definition of macro 'MENU_ITEM'
ultralcd.cpp:1101:5: note: in expansion of macro 'MENU_ITEM_EDIT'
ultralcd.cpp:1102: error: 'LCD_MAX_TEMP_OFFSET' was not declared in this scope
MENU_ITEM_EDIT(float3, MSG_MAX, &autotemp_max, 0, HEATER_0_MAXTEMP + LCD_MAX_TEMP_OFFSET);
ultralcd.cpp:1102:5: note: in expansion of macro 'MENU_ITEM_EDIT'
ultralcd.cpp: In function 'void lcd_control_temperature_preheat_pla_settings_menu()':
ultralcd.cpp:1180: error: 'LCD_MAX_TEMP_OFFSET' was not declared in this scope
MENU_ITEM_EDIT(int3, MSG_NOZZLE, &plaPreheatHotendTemp, HEATER_0_MINTEMP, HEATER_0_MAXTEMP + LCD_MAX_TEMP_OFFSET);
ultralcd.cpp:1180:5: note: in expansion of macro 'MENU_ITEM_EDIT'
ultralcd.cpp: In function 'void lcd_control_temperature_preheat_abs_settings_menu()':
ultralcd.cpp:1201: error: 'LCD_MAX_TEMP_OFFSET' was not declared in this scope
MENU_ITEM_EDIT(int3, MSG_NOZZLE, &absPreheatHotendTemp, HEATER_0_MINTEMP, HEATER_0_MAXTEMP + LCD_MAX_TEMP_OFFSET);
ultralcd.cpp:1201:5: note: in expansion of macro 'MENU_ITEM_EDIT'
ultralcd.cpp: In function 'void lcd_control_temperature_preheat_gum_settings_menu()':
ultralcd.cpp:1222: error: 'LCD_MAX_TEMP_OFFSET' was not declared in this scope
MENU_ITEM_EDIT(int3, MSG_NOZZLE, &gumPreheatHotendTemp, HEATER_0_MINTEMP, HEATER_0_MAXTEMP + LCD_MAX_TEMP_OFFSET);
ultralcd.cpp:1222:5: note: in expansion of macro 'MENU_ITEM_EDIT'
#include LiquidCrystal.h// library for character LCD
Re: MarlinKimbra 4.2.x September 13, 2015 06:41PM |
Re: MarlinKimbra 4.2.x September 13, 2015 06:49PM |
Re: MarlinKimbra 4.2.x September 14, 2015 01:20AM |
Re: MarlinKimbra 4.2.x September 14, 2015 02:06AM |
Da inesperto in materia credo che questi "minestroni" poi è difficile capire dove sia il problemaQuote
monte.m79
La versione 4.2 l'ho scaricata dal configuratore inserendo il file della 4.1.5
Re: MarlinKimbra 4.2.x September 14, 2015 03:50AM |
Re: MarlinKimbra 4.2.x September 14, 2015 05:03AM |
#define INVERT_E0_DIR true
Re: MarlinKimbra 4.2.x September 14, 2015 06:08AM |
Re: MarlinKimbra 4.2.x September 14, 2015 07:32AM |
* Configuration_Overall.h
* Here you can define all your custom settings and they will overwrite configurations in the main configuration files.
#define DEFAULT_AXIS_STEPS_PER_UNIT {160,160,3200,495,495,495,495} // X, Y, Z, E0...(per extruder). Default steps per unit
//X axis pins #define X_STEP_PIN ORIG_X_STEP_PIN #define X_DIR_PIN ORIG_X_DIR_PIN #define X_ENABLE_PIN ORIG_X_ENABLE_PIN
//X axis pins #define X_STEP_PIN ORIG_X_STEP_PIN #define X_DIR_PIN 111 // Esempio di nuovo pin #define X_ENABLE_PIN ORIG_X_ENABLE_PIN
Re: MarlinKimbra 4.2.x September 14, 2015 07:55AM |
Re: MarlinKimbra 4.2.x September 17, 2015 12:11PM |
Re: MarlinKimbra 4.2.x September 17, 2015 12:29PM |
Re: MarlinKimbra 4.2.x September 17, 2015 12:34PM |
Re: MarlinKimbra 4.2.x September 18, 2015 11:38AM |
Re: MarlinKimbra 4.2.x September 18, 2015 02:52PM |
Re: MarlinKimbra 4.2.x September 18, 2015 05:17PM |
MagoKimbra
Mi sa che ti sei sbagliato, perché se selezioni 4.2.0 dev scarica la dev ho appena provato... Riprova...
Re: MarlinKimbra 4.2.x September 19, 2015 04:37PM |
Re: MarlinKimbra 4.2.x September 20, 2015 02:10PM |
Re: MarlinKimbra 4.2.x September 21, 2015 03:05AM |
Re: MarlinKimbra 4.2.x September 21, 2015 04:13AM |
Re: MarlinKimbra 4.2.x September 21, 2015 05:54AM |
Re: MarlinKimbra 4.2.x September 21, 2015 08:42AM |
#define DEACTIVATE_SERVOS_AFTER_MOVE
