FILAMENT_END_SWITCH & M600 attenti a quei due! September 18, 2015 02:31AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 18, 2015 02:38AM |
/********************************************************************************** **************************** Filament Runout sensor ****************************** ********************************************************************************** * * * Filament runout sensor such as a mechanical or opto endstop to check the * * existence of filament * * It is assumed that when logic high = filament available and when logic * * low = filament run out * * Single extruder only at this point (extruder 0) * * * * Uncomment FILAMENT_RUNOUT_SENSOR to enable this feature * * You also need to set FILRUNOUT_PIN in Configuration_pins.h * * * **********************************************************************************/ //#define FILAMENT_RUNOUT_SENSOR #define FILRUNOUT_PIN_INVERTING true // Should be uncommented and true or false should assigned #define ENDSTOPPULLUP_FIL_RUNOUT // Uncomment to use internal pullup for filament runout pins if the sensor is defined. #define FILAMENT_RUNOUT_SCRIPT "M600" // Script execute when filament run out /**********************************************************************************/
#if ENABLED(FILAMENT_RUNOUT_SENSOR) #define FILRUNOUT_PIN -1 #endif
#define FILAMENT_RUNOUT_SCRIPT "M600 X0 Y0 E-100" // Script execute when filament run out
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 18, 2015 03:05AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 18, 2015 03:13AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 18, 2015 04:10AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 18, 2015 06:13AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 18, 2015 07:07AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 07:53AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 08:43AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 09:35AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 09:47AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 11:17AM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 12:06PM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 12:17PM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 12:24PM |
Re: FILAMENT_END_SWITCH & M600 attenti a quei due! September 25, 2015 12:31PM |
