Salve a tutti! Ho da poco acquistato la radds e il relativo lcd ma non riesco a caricare con marlinkimbra il firmware nella scheda, riesco a caricarlo solo se disabilito l'lcd radds. Riporto gli errori che mi sono venuti fuori.
Arduino:1.6.11 (Windows 10), Scheda:"Arduino Due (Programming Port)"
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_main_menu()':
sketch\src\lcd\ultralcd.cpp:247:29: error: 'LCD_BACK_CLICKED' was not declared in this scope
bool wasBackClicked = LCD_BACK_CLICKED; \
sketch\src\lcd\ultralcd.cpp:275:24: note: in expansion of macro '_START_SCREEN'
#define START_MENU() _START_SCREEN(bool wasClicked = LCD_CLICKED, true)
sketch\src\lcd\ultralcd.cpp:672:5: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_tune_menu()':
sketch\src\lcd\ultralcd.cpp:869:5: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_preheat_pla_menu()':
sketch\src\lcd\ultralcd.cpp:1094:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_preheat_abs_menu()':
sketch\src\lcd\ultralcd.cpp:1116:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_preheat_gum_menu()':
sketch\src\lcd\ultralcd.cpp:1138:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_prepare_menu()':
sketch\src\lcd\ultralcd.cpp:1375:5: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void _lcd_move_menu_axis()':
sketch\src\lcd\ultralcd.cpp:1642:5: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_move_menu()':
sketch\src\lcd\ultralcd.cpp:1694:5: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_control_menu()':
sketch\src\lcd\ultralcd.cpp:1713:5: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_control_temperature_menu()':
sketch\src\lcd\ultralcd.cpp:1816:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_control_temperature_preheat_pla_settings_menu()':
sketch\src\lcd\ultralcd.cpp:1958:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_control_temperature_preheat_abs_settings_menu()':
sketch\src\lcd\ultralcd.cpp:1979:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_control_temperature_preheat_gum_settings_menu()':
sketch\src\lcd\ultralcd.cpp:2000:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_control_motion_menu()':
sketch\src\lcd\ultralcd.cpp:2026:5: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_control_volumetric_menu()':
sketch\src\lcd\ultralcd.cpp:2104:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_sdcard_menu()':
sketch\src\lcd\ultralcd.cpp:2284:7: note: in expansion of macro 'START_MENU'
START_MENU();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_info_stats_menu()':
sketch\src\lcd\ultralcd.cpp:268:26: note: in expansion of macro '_START_SCREEN'
#define START_SCREEN() _START_SCREEN(NOOP, false)
sketch\src\lcd\ultralcd.cpp:2357:7: note: in expansion of macro 'START_SCREEN'
START_SCREEN();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_info_thermistors_menu()':
sketch\src\lcd\ultralcd.cpp:2376:7: note: in expansion of macro 'START_SCREEN'
START_SCREEN();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_info_board_menu()':
sketch\src\lcd\ultralcd.cpp:2428:7: note: in expansion of macro 'START_SCREEN'
START_SCREEN();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_info_firmware_menu()':
sketch\src\lcd\ultralcd.cpp:2449:7: note: in expansion of macro 'START_SCREEN'
START_SCREEN();
sketch\src\lcd\ultralcd.cpp: In function 'void lcd_info_menu()':
sketch\src\lcd\ultralcd.cpp:2466:7: note: in expansion of macro 'START_MENU'
START_MENU();
exit status 1
Errore durante la compilazione per la scheda Arduino Due (Programming Port).
Questo report potrebbe essere più ricco di informazioni con l'opzione
"Mostra un output dettagliato durante la compilazione"
abilitata in File -> Impostazioni
