Chiarimento dopo comando G29 November 08, 2016 04:22PM |
; Default start code
G28 ; Home extruder
M420 S1 ; Abilita ABL
G1 Z15 F{Z_TRAVEL_SPEED}
M107 ; Turn off fan
G90 ; Absolute positioning
M82 ; Extruder in absolute mode
; Activate all used extruder
{IF_EXT0}M104 T0 S{TEMP0}
{IF_BED}M190 S{BED}
G92 E0 ; Reset extruder position
; Wait for all used extruders to reach temperature
{IF_EXT0}M109 T0 S{TEMP0}
Re: Chiarimento dopo comando G29 November 08, 2016 05:04PM |
Re: Chiarimento dopo comando G29 November 09, 2016 06:27AM |
Re: Chiarimento dopo comando G29 November 09, 2016 07:37AM |
MagoKimbra
Allora se hai messo il comando M420 S1 nello start gcode quando stampa attiverà l'ABL, ma tu puoi darlo anche a mano nella linea comandi e quindi quando sposti a mano segue il piano, se non lo dai allora l'ABL è disattivo e non lo seguirà...
Re: Chiarimento dopo comando G29 November 09, 2016 08:07AM |
Re: Chiarimento dopo comando G29 November 09, 2016 08:32AM |
Ho dato il comando m503 e mi vengono letti i dati dentro la eeprom che sono giusti.Quote
MagoKimbra
Si, dai il comando M503 e leggi la griglia che aveva creato prima...
14:27:37.734 : Echo: 0 +2.81 +2.67 +2.64 +2.57 +2.63 +2.66 +2.67 +2.91 +3.24 14:27:37.734 : Echo: 1 +2.70 +2.50 +2.34 +2.20 +2.28 +2.28 +2.57 +2.75 +3.01 14:27:37.734 : Echo: 2 +2.52 +2.34 +2.16 +2.06 +2.08 +2.19 +2.28 +2.42 +2.70 14:27:37.734 : Echo: 3 +2.42 +2.21 +2.08 +1.87 +1.89 +1.89 +1.99 +2.12 +2.14 14:27:37.734 : Echo: 4 +2.40 +2.17 +1.98 +1.87 +1.85 +1.84 +1.88 +1.85 +1.12 14:27:37.735 : Echo: 5 +2.13 +1.99 +1.90 +1.84 +1.83 +1.79 +1.75 +1.62 +1.10 14:27:37.735 : Echo: 6 +2.14 +2.08 +1.96 +1.91 +1.86 +1.84 +1.70 +1.54 +1.27 14:27:37.735 : Echo: 7 +2.12 +1.98 +2.03 +1.94 +1.91 +1.89 +1.79 +1.58 +1.38 14:27:37.735 : Echo: 8 +2.04 +2.21 +2.40 +2.22 +1.35 +1.44 +1.78 +1.83 +1.61 14:27:37.735 : Stats: Total: 0, Finished: 0, Failed: 0 14:27:37.735 : Stats: Total print time: 0s, Power on time: 4m 40s 14:27:37.735 : Stats: Filament used: 0Km 0m 0cm 0mmquesta è la griglia con i rilevamenti alti di 2mm su tutti i punti.
Re: Chiarimento dopo comando G29 November 09, 2016 08:44AM |
Re: Chiarimento dopo comando G29 November 09, 2016 02:16PM |
Re: Chiarimento dopo comando G29 November 09, 2016 05:27PM |
20:16:04.422 : Bed Z-Height at X:0.00 Y:0.00 = -0.0636 New Z probe offset = -2.0364il mio zoffset era impostato a -2.1 dovrei avere la sonda che rileva un dislivello su X0 e Y0 di 0.0636 che in teoria dovrebbero essere discreti, ma come detto sopra in alcuni punti tocca.
Re: Chiarimento dopo comando G29 November 09, 2016 06:27PM |
00:25:18.069 : Echo:Bilinear Leveling Grid:
00:25:18.069 : Echo: 0 1 2 3 4 5 6 7 8 9 10
00:25:18.069 : Echo: 0 -0.22 -0.13 -0.03 -0.09 -0.14 -0.14 -0.16 -0.21 -0.24 -0.24 -0.25
00:25:18.093 : Echo: 1 -0.18 -0.17 -0.08 +0.05 -0.08 -0.11 -0.20 -0.21 -0.22 -0.24 -0.29
00:25:18.093 : Echo: 2 -0.18 -0.14 -0.08 -0.08 -0.06 -0.06 -0.15 -0.22 -0.24 -0.22 -0.30
00:25:18.093 : Echo: 3 -0.11 -0.02 -0.02 +0.01 -0.05 -0.03 -0.11 -0.14 -0.22 -0.24 -0.26
00:25:18.093 : Echo: 4 -0.06 +0.02 +0.04 +0.01 -0.04 -0.08 -0.17 -0.19 -0.26 -0.29 -0.33
00:25:18.093 : Echo: 5 +0.01 +0.06 +0.05 +0.00 -0.01 -0.11 -0.16 -0.16 -0.18 -0.13 -0.29
00:25:18.108 : Echo: 6 -0.00 -0.00 -0.01 -0.07 -0.11 -0.04 -0.20 -0.30 -0.31 -0.36 -0.42
00:25:18.108 : Echo: 7 -0.02 -0.01 -0.02 -0.05 -0.14 -0.20 -0.23 -0.28 -0.30 -0.37 -0.50
00:25:18.108 : Echo: 8 +0.01 -0.01 -0.09 -0.12 -0.17 -0.19 -0.24 -0.35 -0.41 -0.39 -0.46
00:25:18.108 : Echo: 9 +0.01 -0.06 -0.12 -0.22 -0.33 -0.33 -0.27 -0.31 -0.45 -0.51 -0.49
00:25:18.108 : Echo:10 +0.02 -0.12 -0.32 -0.51 -0.49 -0.28 -0.28 -0.30 -0.39 -0.55 -0.61
Re: Chiarimento dopo comando G29 November 10, 2016 02:20AM |
Re: Chiarimento dopo comando G29 November 10, 2016 04:20PM |
Re: Chiarimento dopo comando G29 November 11, 2016 10:06AM |
Re: Chiarimento dopo comando G29 November 11, 2016 10:16AM |
Re: Chiarimento dopo comando G29 November 11, 2016 05:26PM |
Re: Chiarimento dopo comando G29 November 11, 2016 07:01PM |
Re: Chiarimento dopo comando G29 November 12, 2016 01:47PM |
Arduino:1.6.11 (Windows 10), Scheda:"Arduino/Genuino Mega or Mega 2560, ATmega2560 (Mega 2560)"
sketch\src\eeprom\eeprom.cpp: In static member function 'static void EEPROM::RetrieveSettings()':
sketch\src\eeprom\eeprom.cpp:539:28: error: 'Config_PrintSettings' was not declared in this scope
Config_PrintSettings();
exit status 1
Errore durante la compilazione per la scheda Arduino/Genuino Mega or Mega 2560.
Questo report potrebbe essere più ricco di informazioni con l'opzione
"Mostra un output dettagliato durante la compilazione"
abilitata in File -> Impostazioni
Re: Chiarimento dopo comando G29 November 13, 2016 04:47AM |
Re: Chiarimento dopo comando G29 November 13, 2016 04:51AM |
Version 4.3.06_dev Add Auto report temp width M155 Add new capabilities string width M115 Add M155 Set temperature auto-report interval Add M320 Activate autolevel Add M321 Deactivate autoleveling Add M322 Reset auto leveling matrix Change M11 in M530 Add M530 Enables explicit printing mode (S1) or disables it (S0). L can set layer count Add M531 Define filename being printed Add M532 update current print state progress (X=0..100) and layer L
Re: Chiarimento dopo comando G29 November 13, 2016 08:14AM |
Re: Chiarimento dopo comando G29 November 13, 2016 08:58AM |
Re: Chiarimento dopo comando G29 November 13, 2016 09:21AM |
Re: Chiarimento dopo comando G29 November 13, 2016 03:40PM |
21:32:10.105 : Echo:Bilinear Leveling Grid: 21:32:10.105 : Echo: 0 1 2 3 4 5 6 7 8 21:32:10.105 : Echo: 0 +0.83 +0.82 +0.90 +1.12 +1.38 +1.50 +1.85 +2.47 +2.93 21:32:10.105 : Echo: 1 +0.63 +0.56 +0.60 +0.70 +0.94 +1.22 +1.76 +2.11 +2.40 21:32:10.105 : Echo: 2 +0.32 +0.27 +0.28 +0.44 +0.67 +1.00 +1.36 +1.55 +1.94 21:32:10.105 : Echo: 3 +0.03 -0.03 -0.07 +0.07 +0.27 +0.55 +0.84 +1.24 +1.40 21:32:10.105 : Echo: 4 -0.19 -0.25 -0.23 -0.12 +0.09 +0.38 +0.62 +0.84 +0.59 21:32:10.105 : Echo: 5 -0.39 -0.41 -0.40 -0.27 -0.14 +0.07 +0.28 +0.42 +0.39 21:32:10.105 : Echo: 6 -0.42 -0.43 -0.41 -0.30 -0.16 -0.01 +0.15 +0.16 +0.20 21:32:10.105 : Echo: 7 -0.54 -0.52 -0.41 -0.29 -0.18 -0.06 -0.01 +0.06 +0.06 21:32:10.105 : Echo: 8 -0.24 +0.16 -0.23 -0.02 -0.03 -0.07 -0.08 -0.04 -0.04 21:32:10.105 : X:25.00 Y:82.00 Z:17.17 E:0.00 Count Alpha:9904 Beta:12472 Teta:16903 21:32:21.918 : Settings Stored (633 bytes)Al centro con G30 X0 Y0 rilevo un errore di
21:28:09.218 : Bed X:0.00 Y: 0.00 Z: 0.0375 New Z probe offset = -2.1375
Re: Chiarimento dopo comando G29 November 13, 2016 06:09PM |
If the nozzle touches the center point at the height of 2mm, but not 0 mm, that means
the bed is a convex surface, you should reduce the DELTA_RADIUS from 1 to 0
for example.
*If the print head has reached to 0mm, but hasn’t touched the bed, that means the bed
is a concave surface, you should increase the DELTA_RADIUS from 1 to 2 for
example.
Re: Chiarimento dopo comando G29 November 13, 2016 06:45PM |
DEFAULT_DELTA_RADIUS (DELTA_SMOOTH_ROD_OFFSET - DELTA_EFFECTOR_OFFSET - DELTA_CARRIAGE_OFFSET)
Re: Chiarimento dopo comando G29 November 14, 2016 03:13AM |
Re: Chiarimento dopo comando G29 November 14, 2016 03:15AM |
Re: Chiarimento dopo comando G29 November 14, 2016 12:57PM |
MagoKimbra
yes, inizia con una precisione di 0.2 G30 A0.2
18:42:31.858 : Starting Auto Calibration... 18:42:31.858 : Calibration precision: +/-0.20 mm 18:43:09.246 : | Z-Tower Endstop Offsets 18:43:09.246 : | -0.1041 X:0.0000 Y:0.0000 Z:0.0000 18:43:09.246 : | -0.0875 -0.3791 Tower Offsets 18:43:09.246 : | -0.1750 A:0.00 B:0.00 C:0.00 18:43:09.246 : | 0.2135 1.0279 I:0.00 J:0.00 K:0.00 18:43:09.246 : | 0.8033 Delta Radius: 91.0000 18:43:09.246 : | X-Tower Y-Tower Diagonal Rod: 196.0000 18:43:09.246 : Iteration: 1 18:43:09.246 : Checking/Adjusting endstop offsets 18:43:21.796 : x:0.1635 (adj:0.1635) y:0.9779 (adj:0.9779) z:-0.0791 (adj:-0.0791) 18:43:21.796 : X=OK Y=ERROR Z=OK 18:43:35.855 : x:-0.1240 (adj:0.0395) y:0.0404 (adj:1.0184) z:-0.2666 (adj:-0.3458) 18:43:35.855 : X=OK Y=OK Z=ERROR 18:43:49.843 : x:-0.0115 (adj:0.0280) y:-0.0096 (adj:1.0088) z:-0.0916 (adj:-0.4374) 18:43:49.843 : X=OK Y=OK Z=OK 18:43:49.843 : High endstop:1.0088 18:43:49.843 : Reducing Build height by 1.01 18:44:16.801 : | Z-Tower Endstop Offsets 18:44:16.832 : | 0.0583 X:-0.9808 Y:0.0000 Z:-1.4462 18:44:16.832 : | -0.5500 -0.0291 Tower Offsets 18:44:16.832 : | -0.5500 A:0.00 B:0.00 C:0.00 18:44:16.832 : | 0.0510 -0.0471 I:0.00 J:0.00 K:0.00 18:44:16.832 : | 0.0158 Delta Radius: 91.0000 18:44:16.832 : | X-Tower Y-Tower Diagonal Rod: 196.0000 18:44:16.832 : Checking delta radius 18:44:18.305 : Adjusting Delta Radius 18:44:18.305 : Bed level center = -0.55 18:44:31.009 : x:0.0510 (adj:-0.9298) y:-0.0346 (adj:-0.0346) z:0.0708 (adj:-1.3754) 18:44:31.009 : X=OK Y=OK Z=OK 18:44:31.009 : High endstop:-0.0346 18:44:34.497 : c:-0.5369 delta radius:91.0000 prec:0.010 tries:0 done:false 18:44:47.171 : x:0.1350 (adj:-0.7947) y:-0.0295 (adj:-0.0640) z:0.1883 (adj:-1.1870) 18:44:47.171 : X=OK Y=OK Z=OK 18:44:47.171 : High endstop:-0.0640 18:44:50.665 : c:-0.4989 delta radius:91.2000 prec:0.010 tries:0 done:false 18:45:03.400 : x:0.0925 (adj:-0.7023) y:0.0137 (adj:-0.0503) z:0.0098 (adj:-1.1773) 18:45:03.400 : X=OK Y=OK Z=OK 18:45:03.400 : High endstop:-0.0503 18:45:06.887 : c:-0.4519 delta radius:91.4000 prec:0.010 tries:0 done:false 18:45:19.607 : x:0.1146 (adj:-0.5877) y:-0.0057 (adj:-0.0560) z:0.0283 (adj:-1.1489) 18:45:19.607 : X=OK Y=OK Z=OK 18:45:19.607 : High endstop:-0.0560 18:45:23.086 : c:-0.3877 delta radius:91.6000 prec:0.010 tries:0 done:false 18:45:35.852 : x:0.1110 (adj:-0.4767) y:0.0258 (adj:-0.0302) z:0.0377 (adj:-1.1112) 18:45:35.852 : X=OK Y=OK Z=OK 18:45:35.852 : High endstop:-0.0302 18:45:39.314 : c:-0.3250 delta radius:91.8000 prec:0.010 tries:0 done:false 18:45:52.081 : x:0.1076 (adj:-0.3691) y:-0.0307 (adj:-0.0609) z:0.0207 (adj:-1.0905) 18:45:52.081 : X=OK Y=OK Z=OK 18:45:52.081 : High endstop:-0.0609 18:45:55.560 : c:-0.2353 delta radius:92.0000 prec:0.010 tries:0 done:false 18:46:08.310 : x:0.1296 (adj:-0.2395) y:-0.0488 (adj:-0.1097) z:0.0892 (adj:-1.0013) 18:46:08.310 : X=OK Y=OK Z=OK 18:46:08.310 : High endstop:-0.1097 18:46:11.767 : c:-0.1669 delta radius:92.2000 prec:0.010 tries:1 done:false 18:46:24.524 : x:0.1518 (adj:-0.0877) y:0.0080 (adj:-0.1017) z:0.0749 (adj:-0.9265) 18:46:24.524 : X=OK Y=OK Z=OK 18:46:24.524 : High endstop:-0.0877 18:46:27.996 : c:-0.1261 delta radius:92.4000 prec:0.010 tries:2 done:false 18:46:40.799 : x:0.1368 (adj:0.0491) y:-0.0358 (adj:-0.1375) z:-0.0165 (adj:-0.9430) 18:46:40.799 : X=OK Y=OK Z=OK 18:46:40.799 : High endstop:0.0491 18:46:40.799 : Reducing Build height by 0.05 18:46:44.255 : c:-0.0090 delta radius:92.6000 prec:0.010 tries:2 done:true 18:46:44.255 : Iteration: 2 18:46:44.255 : Checking/Adjusting endstop offsets 18:46:57.044 : x:0.0368 (adj:0.0368) y:0.0142 (adj:-0.1725) z:0.0585 (adj:-0.9336) 18:46:57.044 : X=OK Y=OK Z=OK 18:46:57.044 : High endstop:0.0368 18:46:57.044 : Reducing Build height by 0.04 18:47:24.305 : | Z-Tower Endstop Offsets 18:47:24.305 : | -0.0040 X:0.0000 Y:-0.2093 Z:-0.9703 18:47:24.305 : | -0.6902 -0.0163 Tower Offsets 18:47:24.305 : | -0.0715 A:0.00 B:0.00 C:0.00 18:47:24.305 : | -0.0007 0.0017 I:0.00 J:0.00 K:0.00 18:47:24.305 : | -0.0243 Delta Radius: 92.6000 18:47:24.305 : | X-Tower Y-Tower Diagonal Rod: 196.0000 18:47:24.305 : Checking for tower geometry errors.. 18:47:24.305 : x_diff:0.68945 y_diff:0.01799 z_diff:0.02032 high_diff:0.68945 18:47:24.305 : xy_equal = false 18:47:24.305 : xz_equal = false 18:47:24.305 : yz_equal = true 18:47:24.305 : Opp Range = 0.67384 18:47:24.305 : t1:Err t2:OK t3:OK 18:47:24.305 : Tower1 Error: Adjusting 18:47:33.129 : tower:-0.0007 opptower:-0.6777 tower radius adj:0.0000 done:false 18:47:45.825 : x:-0.0132 (adj:-0.0132) y:-0.0233 (adj:-0.2326) z:0.0085 (adj:-0.9618) 18:47:45.825 : X=OK Y=OK Z=OK 18:47:45.825 : High endstop:-0.0132 18:47:56.193 : tower:-0.1613 opptower:-0.4014 tower radius adj:-1.0000 done:false 18:48:08.859 : x:-0.1613 (adj:-0.1745) y:0.0516 (adj:-0.1811) z:0.0211 (adj:-0.9408) 18:48:08.859 : X=OK Y=OK Z=OK 18:48:08.859 : High endstop:-0.1745 18:48:19.142 : tower:-0.2520 opptower:-0.2146 tower radius adj:-2.0000 done:false 18:48:31.754 : x:-0.2145 (adj:-0.3890) y:0.0519 (adj:-0.1292) z:0.0331 (adj:-0.9077) 18:48:31.754 : X=ERROR Y=OK Z=OK 18:48:45.761 : x:-0.0895 (adj:-0.4784) y:0.0269 (adj:-0.1023) z:0.0081 (adj:-0.8996) 18:48:45.761 : X=OK Y=OK Z=OK 18:48:45.761 : High endstop:-0.1023 18:48:56.059 : tower:0.0741 opptower:-0.4271 tower radius adj:-1.5000 done:false 18:49:08.675 : x:0.0866 (adj:-0.3918) y:-0.0232 (adj:-0.1255) z:-0.0540 (adj:-0.9536) 18:49:08.675 : X=OK Y=OK Z=OK 18:49:08.675 : High endstop:-0.1255 18:49:18.921 : tower:-0.0345 opptower:-0.3025 tower radius adj:-1.7500 done:false 18:49:31.539 : x:-0.0470 (adj:-0.4388) y:-0.0357 (adj:-0.1612) z:0.0337 (adj:-0.9200) 18:49:31.539 : X=OK Y=OK Z=OK 18:49:31.539 : High endstop:-0.1612 18:49:41.800 : tower:-0.0395 opptower:-0.2271 tower radius adj:-2.0000 done:false 18:49:54.381 : x:-0.0395 (adj:-0.4783) y:0.0394 (adj:-0.1218) z:0.0456 (adj:-0.8744) 18:49:54.381 : X=OK Y=OK Z=OK 18:49:54.381 : High endstop:-0.1218 18:50:04.663 : tower:-0.0476 opptower:-0.2146 tower radius adj:-2.2500 done:false 18:50:17.244 : x:-0.0476 (adj:-0.5259) y:0.0019 (adj:-0.1199) z:0.0206 (adj:-0.8538) 18:50:17.244 : X=OK Y=OK Z=OK 18:50:17.244 : High endstop:-0.1199Mi correggo dopo 13 minuti ora è tornata in Home per poi riabbassarsi e rifare tutto dacapo
19:10:32.144 : Tower Positions changed .. Homing
19:11:37.155 : | Z-Tower Endstop Offsets
19:11:37.155 : | -1.3014 X:-0.6698 Y:-0.1601 Z:-0.5458
19:11:37.155 : | -1.1457 -1.1242 Tower Offsets
19:11:37.155 : | -1.0269 A:0.00 B:0.00 C:0.00
19:11:37.155 : | 0.0474 -0.6430 I:-2.94 J:0.00 K:0.00
19:11:37.155 : | -0.5196 Delta Radius: 92.7500
19:11:37.155 : | X-Tower Y-Tower Diagonal Rod: 196.0000
19:11:37.155 : Iteration: 3
19:11:37.155 : Checking/Adjusting endstop offsets
19:11:50.092 : x:0.0099 (adj:-0.6598) y:-0.5930 (adj:-0.7531) z:-1.2514 (adj:-1.7972)
19:11:50.092 : X=OK Y=ERROR Z=ERROR
19:12:04.046 : x:0.2099 (adj:-0.4499) y:0.0945 (adj:-0.6586) z:-0.0264 (adj:-1.8237)
19:12:04.046 : X=ERROR Y=OK Z=OK
19:12:18.022 : x:0.0599 (adj:-0.3900) y:0.0320 (adj:-0.6266) z:-0.0264 (adj:-1.8501)
19:12:18.022 : X=OK Y=OK Z=OK
19:12:18.022 : High endstop:-0.3900
19:12:44.975 : | Z-Tower Endstop Offsets
19:12:44.975 : | 0.1361 X:-0.3900 Y:-0.6266 Z:-1.8501
19:12:44.975 : | -0.0832 -0.3617 Tower Offsets
19:12:44.975 : | -0.3644 A:0.00 B:0.00 C:0.00
19:12:44.975 : | 0.0349 -0.0430 I:-2.94 J:0.00 K:0.00
19:12:44.975 : | -0.3571 Delta Radius: 92.7500
19:12:44.975 : | X-Tower Y-Tower Diagonal Rod: 196.0000
19:12:44.975 : Checking delta radius
19:12:46.432 : Adjusting Delta Radius
19:12:46.432 : Bed level center = -0.36
19:12:59.132 : x:0.0224 (adj:-0.3676) y:-0.0680 (adj:-0.6945) z:0.0236 (adj:-1.8265)
19:12:59.132 : X=OK Y=OK Z=OK
19:12:59.132 : High endstop:-0.3676
19:13:02.577 : c:-0.2894 delta radius:92.7500 prec:0.010 tries:0 done:false
19:13:15.268 : x:0.1146 (adj:-0.2530) y:-0.0486 (adj:-0.7431) z:0.1099 (adj:-1.7167)
19:13:15.268 : X=OK Y=OK Z=OK
19:13:15.268 : High endstop:-0.2530
19:13:18.721 : c:-0.2222 delta radius:92.9500 prec:0.010 tries:0 done:false
19:13:31.404 : x:0.1480 (adj:-0.1050) y:-0.0527 (adj:-0.7958) z:0.1425 (adj:-1.5742)
19:13:31.404 : X=OK Y=OK Z=OK
19:13:31.404 : High endstop:-0.1050
19:13:34.862 : c:-0.1922 delta radius:93.1500 prec:0.010 tries:1 done:false
19:13:47.575 : x:0.1157 (adj:0.0108) y:0.0046 (adj:-0.7912) z:0.0520 (adj:-1.5222)
19:13:47.575 : X=OK Y=OK Z=OK
19:13:47.575 : High endstop:0.0108
19:13:47.575 : Reducing Build height by 0.01
19:13:51.038 : c:-0.1245 delta radius:93.3500 prec:0.010 tries:2 done:false
19:14:03.737 : x:0.1881 (adj:0.1881) y:0.0002 (adj:-0.8018) z:0.0742 (adj:-1.4588)
19:14:03.737 : X=OK Y=OK Z=OK
19:14:03.737 : High endstop:0.1881
19:14:03.737 : Reducing Build height by 0.19
19:14:07.185 : c:-0.0669 delta radius:93.5500 prec:0.010 tries:3 done:false
19:14:19.917 : x:0.1098 (adj:0.1098) y:-0.0166 (adj:-1.0064) z:0.0716 (adj:-1.5753)
19:14:19.917 : X=OK Y=OK Z=OK
19:14:19.917 : High endstop:0.1098
19:14:19.917 : Reducing Build height by 0.11
19:14:23.360 : c:-0.0131 delta radius:93.7500 prec:0.020 tries:0 done:false
19:14:36.117 : x:0.1033 (adj:0.1033) y:0.0163 (adj:-1.0999) z:-0.0558 (adj:-1.7408)
19:14:36.117 : X=OK Y=OK Z=OK
19:14:36.117 : High endstop:0.1033
19:14:36.117 : Reducing Build height by 0.10
19:14:39.547 : c:0.0636 delta radius:93.9500 prec:0.020 tries:1 done:false
19:14:52.289 : x:0.0310 (adj:0.0310) y:-0.0626 (adj:-1.2658) z:0.0704 (adj:-1.7738)
19:14:52.289 : X=OK Y=OK Z=OK
19:14:52.289 : High endstop:0.0310
19:14:52.289 : Reducing Build height by 0.03
19:14:55.731 : c:0.0285 delta radius:93.8500 prec:0.020 tries:2 done:false
19:15:08.487 : x:-0.0278 (adj:-0.0278) y:-0.0541 (adj:-1.3510) z:-0.0534 (adj:-1.8582)
19:15:08.487 : X=OK Y=OK Z=OK
19:15:08.487 : High endstop:-0.0278
19:15:11.928 : c:0.0119 delta radius:93.7500 prec:0.020 tries:2 done:true
19:15:11.928 : Iteration: 4
19:15:11.928 : Checking/Adjusting endstop offsets
Re: Chiarimento dopo comando G29 November 14, 2016 01:29PM |
19:15:51.808 : Checking for tower geometry errors.. 19:15:51.808 : x_diff:0.12747 y_diff:0.51157 z_diff:0.32607 high_diff:0.51157 19:15:51.808 : xy_equal = false 19:15:51.808 : xz_equal = true 19:15:51.808 : yz_equal = true 19:15:51.808 : Opp Range = 0.33548 19:15:51.808 : t1:OK t2:Err t3:Err 19:15:51.808 : Tower geometry OK 19:15:51.808 : Checking Diagonal Rod Length 19:16:08.917 : target:-0.2751 c:-0.0631 adj:0.20000 19:16:26.134 : target:-0.4981 c:-0.3030 adj:0.20000 19:16:43.436 : target:-0.6899 c:-0.5241 adj:0.20000 19:17:00.800 : target:-0.9150 c:-0.7492 adj:0.20000 19:17:18.264 : target:-1.1091 c:-0.9639 adj:0.20000 19:17:35.829 : target:-1.3098 c:-1.1723 adj:0.20000 19:17:53.494 : target:-1.5138 c:-1.4347 adj:0.20000 19:18:11.274 : target:-1.7100 c:-1.6492 adj:0.20000 19:18:29.130 : target:-1.9342 c:-1.8532 adj:0.20000 19:18:47.111 : target:-2.1634 c:-2.0989 adj:0.20000 19:19:05.161 : target:-2.3852 c:-2.3215 adj:0.20000 19:19:23.327 : target:-2.5807 c:-2.5503 adj:0.20000 19:19:41.594 : target:-2.7821 c:-2.7770 adj:0.00000 19:19:41.594 : Diagonal Rod Length changed .. Homing 19:20:42.249 : | Z-Tower Endstop Offsets 19:20:42.249 : | -0.5501 X:-0.0180 Y:-1.3551 Z:-1.8741 19:20:42.249 : | -0.1816 -1.1028 Tower Offsets 19:20:42.249 : | -0.5645 A:0.00 B:0.00 C:0.00 19:20:42.249 : | -0.6680 -0.0357 I:-2.94 J:0.00 K:0.00 19:20:42.249 : | -0.5992 Delta Radius: 93.7500 19:20:42.249 : | X-Tower Y-Tower Diagonal Rod: 198.4000 19:20:42.249 : Iteration: 5 19:20:42.249 : Checking/Adjusting endstop offsets 19:20:55.053 : x:-0.6680 (adj:-0.6860) y:-0.0107 (adj:-1.3657) z:-0.5001 (adj:-2.3742) 19:20:55.053 : X=ERROR Y=OK Z=ERROR 19:21:09.022 : x:-0.1430 (adj:-0.8290) y:0.0644 (adj:-1.3014) z:-0.1126 (adj:-2.4867) 19:21:09.022 : X=OK Y=OK Z=OK 19:21:09.022 : High endstop:-0.8290 19:21:35.845 : | Z-Tower Endstop Offsets 19:21:35.845 : | -0.0376 X:-0.8290 Y:-1.3014 Z:-2.4867 19:21:35.845 : | -0.0192 -0.3778 Tower Offsets 19:21:35.847 : | -0.2145 A:0.00 B:0.00 C:0.00 19:21:35.847 : | -0.0305 -0.0107 I:-2.94 J:0.00 K:0.00 19:21:35.847 : | -0.3117 Delta Radius: 93.7500 19:21:35.847 : | X-Tower Y-Tower Diagonal Rod: 198.4000 19:21:35.847 : Checking delta radius 19:21:37.255 : Adjusting Delta Radius 19:21:37.255 : Bed level center = -0.21 19:21:49.936 : x:-0.0055 (adj:-0.8345) y:0.0143 (adj:-1.2871) z:-0.0250 (adj:-2.5118) 19:21:49.936 : X=OK Y=OK Z=OK 19:21:49.936 : High endstop:-0.8345 19:21:53.362 : c:-0.2020 delta radius:93.7500 prec:0.010 tries:0 done:false 19:22:06.012 : x:0.0253 (adj:-0.8092) y:0.0097 (adj:-1.2774) z:0.0340 (adj:-2.4777) 19:22:06.012 : X=OK Y=OK Z=OK 19:22:06.012 : High endstop:-0.8092 19:22:09.442 : c:-0.1224 delta radius:93.9500 prec:0.010 tries:1 done:false 19:22:22.110 : x:0.0987 (adj:-0.7104) y:-0.0566 (adj:-1.3339) z:0.0462 (adj:-2.4315) 19:22:22.110 : X=OK Y=OK Z=OK 19:22:22.110 : High endstop:-0.7104 19:22:25.520 : c:-0.0616 delta radius:94.1500 prec:0.010 tries:2 done:false 19:22:38.170 : x:0.1416 (adj:-0.5688) y:-0.0108 (adj:-1.3447) z:0.1297 (adj:-2.3018) 19:22:38.170 : X=OK Y=OK Z=OK 19:22:38.170 : High endstop:-0.5688 19:22:41.597 : c:0.0126 delta radius:94.3500 prec:0.010 tries:3 done:false 19:22:54.270 : x:0.0081 (adj:-0.5607) y:-0.0648 (adj:-1.4095) z:-0.0067 (adj:-2.3085) 19:22:54.270 : X=OK Y=OK Z=OK 19:22:54.270 : High endstop:-0.5607 19:22:57.679 : c:-0.0265 delta radius:94.2500 prec:0.020 tries:0 done:false 19:23:10.346 : x:0.0536 (adj:-0.5071) y:-0.0128 (adj:-1.4223) z:0.0748 (adj:-2.2337) 19:23:10.346 : X=OK Y=OK Z=OK 19:23:10.346 : High endstop:-0.5071 19:23:13.755 : c:-0.0101 delta radius:94.3000 prec:0.020 tries:0 done:true 19:23:13.755 : Iteration: 6 19:23:13.755 : Checking/Adjusting endstop offsets 19:23:26.444 : x:-0.0339 (adj:-0.5410) y:-0.0003 (adj:-1.4226) z:-0.0127 (adj:-2.2464) 19:23:26.444 : X=OK Y=OK Z=OK 19:23:26.444 : High endstop:-0.5410 19:23:53.266 : | Z-Tower Endstop Offsets 19:23:53.266 : | 0.0248 X:-0.5410 Y:-1.4226 Z:-2.2464 19:23:53.266 : | 0.0122 -0.4005 Tower Offsets 19:23:53.266 : | -0.0351 A:0.00 B:0.00 C:0.00 19:23:53.266 : | -0.0089 0.0247 I:-2.94 J:0.00 K:0.00 19:23:53.266 : | -0.2386 Delta Radius: 94.3000 19:23:53.266 : | X-Tower Y-Tower Diagonal Rod: 198.4000 19:23:53.266 : Checking for tower geometry errors.. 19:23:53.266 : x_diff:0.02104 y_diff:0.42517 z_diff:0.26343 high_diff:0.42517 19:23:53.266 : xy_equal = false 19:23:53.266 : xz_equal = false 19:23:53.266 : yz_equal = true 19:23:53.266 : Opp Range = 0.41266 19:23:53.266 : t1:OK t2:Err t3:Err 19:23:53.266 : Tower geometry OK 19:23:53.266 : Checking Diagonal Rod Length 19:24:10.143 : target:-0.2048 c:-0.0226 adj:0.20000 19:24:27.128 : target:-0.4071 c:-0.2766 adj:0.20000 19:24:44.191 : target:-0.6131 c:-0.5286 adj:0.20000 19:25:01.339 : target:-0.8071 c:-0.6867 adj:0.20000 19:25:18.617 : target:-1.0157 c:-0.8989 adj:0.20000 19:25:35.981 : target:-1.2339 c:-1.1131 adj:0.20000 19:25:53.428 : target:-1.4230 c:-1.3418 adj:0.20000 19:26:10.962 : target:-1.6220 c:-1.5623 adj:0.20000 19:26:28.611 : target:-1.8350 c:-1.7992 adj:0.20000 19:26:46.360 : target:-2.0378 c:-2.0132 adj:0.20000 19:27:04.224 : target:-2.2312 c:-2.2230 adj:0.00000 19:27:04.224 : Diagonal Rod Length changed .. Homing
Re: Chiarimento dopo comando G29 November 14, 2016 02:24PM |
