[PROBLEMI] MK4duo versione 4.3.7 November 12, 2018 12:19PM |
In file included from C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\../../../src/inc/pins.h:28:0, from C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\../../../MK4duo.h:103, from C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\printer.cpp:29: C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\printer.cpp: In static member function 'static void Printer::setup()': C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\../../../src/inc/../boards/1401.h:237:13: error: 'RADDS_EXT_VDD_PIN' was not declared in this scope OUT_WRITE(RADDS_EXT_VDD_PIN, HIGH); \ ^ C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\printer.cpp:132:5: note: in expansion of macro 'MB_SETUP' MB_SETUP; ^ C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\../../../src/inc/../boards/1401.h:238:13: error: 'RADDS_EXT_VDD2_PIN' was not declared in this scope OUT_WRITE(RADDS_EXT_VDD2_PIN, HIGH); ^ C:\Users\dario\AppData\Local\Temp\arduino_build_4130\sketch\src\core\printer\printer.cpp:132:5: note: in expansion of macro 'MB_SETUP' MB_SETUP; ^ Uso la libreria SPI alla versione 1.0 nella cartella: C:\Users\dario\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\SPI Uso la libreria Wire alla versione 1.0 nella cartella: C:\Users\dario\AppData\Local\Arduino15\packages\arduino\hardware\sam\1.6.11\libraries\Wire exit status 1 Errore durante la compilazione per la scheda Arduino Due (Programming Port).Qualcuno sa come risolvere? grazie
Re: [PROBLEMI] MK4duo versione 4.3.7 November 13, 2018 03:22AM |
Re: [PROBLEMI] MK4duo versione 4.3.7 November 13, 2018 11:20AM |
Re: [PROBLEMI] MK4duo versione 4.3.7 November 22, 2018 08:14AM |
Re: [PROBLEMI] MK4duo versione 4.3.7 November 22, 2018 08:23AM |
Re: [PROBLEMI] MK4duo versione 4.3.7 November 22, 2018 08:26AM |
Re: [PROBLEMI] MK4duo versione 4.3.7 November 22, 2018 01:35PM |
Re: [PROBLEMI] MK4duo versione 4.3.7 November 22, 2018 03:07PM |
silvanopas
Ok ,non ho fretta, era solo per avvisarti , comunque provo la 4.3.8 e ti dico, grazie
Re: [PROBLEMI] MK4duo versione 4.3.7 November 22, 2018 03:11PM |
atomino
Sto ancora cercando di far funzionare la 4.3.7 con i driver TB6600.
Ho verificato con l'oscilloscopio il segnale di step sull'asse X che nella versionne 4.3.6 aveva un periodo di 19.6us vedi 436_1.jpg,
e sono riuscito a riproporla sulla 4.3.7 vedi 437_1.jpg con il comando M569 XYZ D1500 P6 R150000,
il parametro P agisce sulla durata dell'impulso, ma sembra che il problema sia nella rampa di accelerazione e decelerazione,
nella fase partenza e poi arresto utilizzando gli spostamenti manuali di Repetier Host ...
Qualche consiglio ?
Re: [PROBLEMI] MK4duo versione 4.3.7 November 24, 2018 05:03AM |
MagoKimbra
silvanopas
Scusami ho appena scaricato la 4.3.7 con laser e display REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER ramps e null'altro compila perfettamente... Non riesco a capire gli errori che hai. Allega il file overall cosi vedo...
Aggiungo anche che non hai scaricato la 4.3.7 ma ancora la 4.3.6 o non so da dove tiri fuori quegli errori sono cose che non esistono più nella 4.3.7...
Re: [PROBLEMI] MK4duo versione 4.3.7 November 25, 2018 03:09PM |
silvanopas
MagoKimbra
silvanopas
Ciao , può essere che per generare la 4.3.7 non va bene partire dal file overall della 4.3.6 ma devo riscrivere tutti i parametri nel configuratore?
Re: [PROBLEMI] MK4duo versione 4.3.7 November 26, 2018 03:08AM |
