Re: Yes, 3D printers can go on fire. January 17, 2014 05:32PM |
Re: Yes, 3D printers can go on fire. January 17, 2014 06:40PM |
cnc dick
I think that's a great idea.This is what I mean people start throwing ideas around brainstorming is what we used to call it all of a sudden one pops out of thin airQuote
dave3d
umdpru: you have just given me an idea. Is it possible to pick up a signal from a smoke detector that can be used to shutdown a printer?
Re: Yes, 3D printers can go on fire. January 17, 2014 06:55PM |
Re: Yes, 3D printers can go on fire. January 17, 2014 07:44PM |
Re: Yes, 3D printers can go on fire. January 17, 2014 07:59PM |
Re: Yes, 3D printers can go on fire. January 17, 2014 10:51PM |
Re: Yes, 3D printers can go on fire. January 18, 2014 10:04AM |
Re: Yes, 3D printers can go on fire. January 18, 2014 12:23PM |
Re: Yes, 3D printers can go on fire. January 18, 2014 09:02PM |
Re: Yes, 3D printers can go on fire. January 19, 2014 04:12AM |
Re: Yes, 3D printers can go on fire. January 24, 2014 09:21AM |
Antslake
Well my printer is back up running. The extruder stepper sounds little funny, but prints are fine. Going to replace that, just in case. I had to repair 8 burnt plugs, and the ramps board. For the time being, I placed aluminum tape along the ramps board to cover the wood and act as a fire barrier. I went to the hardware store to buy a smoke alarm, and they had 2 kinds, a general one, and a more sophisticated one that is trigger by more kinds of smoke, and more sensitive. It can "see" smoke too. It was $27, so I got that going. Next will be my fire retarded shelf, once it's built I will post pictures and specifics.
Printing out wire chains now. When that's done, I will post pictures too. This thread could be a good resource for those wanting to take as many precautions as possible. I love all the ideas.
Re: Yes, 3D printers can go on fire. January 24, 2014 07:30PM |
Re: Yes, 3D printers can go on fire. January 25, 2014 01:29PM |
Re: Yes, 3D printers can go on fire. January 25, 2014 06:05PM |
Re: Yes, 3D printers can go on fire. January 25, 2014 07:38PM |
Re: Yes, 3D printers can go on fire. January 27, 2014 12:01PM |
jamesdanielv
Ok folks lets look at the obvious here. by the time the sensor senses smoke, what good does it do to turn something off? IT IS ALREADY ON FIRE OR COMBUSTING.
at this point you need human intervention, someone to put out the fire, cool down the wires, unplug the circuitry, open up the windows and vent out, some one to calm your wife down and let you still print inside the house. I don't think any 12 volt relay kit can ever do all that! the best bet is a thermal fuse that goes off before the temp reached combustible temperatures as a FAIL SAFE to mechanical and software failures. the ones used in coffee makers are less than 2$
fire alarm is to alert someone who should be at home if you are printing, that something is going on.
Re: Yes, 3D printers can go on fire. January 27, 2014 04:26PM |
Re: Yes, 3D printers can go on fire. January 27, 2014 06:41PM |
jamesdanielv
be home to catch the issue. just because an off switch is included does not mean it will make it any safer.
the best fail safes are
thermal fuses before combustible temp
fuse linkages or fuses to the power supply that blow before shorted wires have a chance to heat up.
proper wiring,
last resort choices that work after a fire is started, and in my opinion as a fail safe this is too late: the 12$ relay fire alarm kit.
Re: Yes, 3D printers can go on fire. January 27, 2014 08:21PM |
Re: Yes, 3D printers can go on fire. January 27, 2014 09:16PM |
Happycamper
Antslake
Did you ever get the wire chain mounted? I have a makerfarm i3 as well and would love to see how you mounted it. Thanks!
Re: Yes, 3D printers can go on fire. January 28, 2014 05:02AM |
Re: Yes, 3D printers can go on fire. January 28, 2014 03:52PM |
dave3d
Got my smoke alarm and relay base and wired them up. It is an Aico Ei141 ionisation smoke alarm with an Ei128R relay base unit.
Tested it with a bit of burning paper. It cuts the mains power a few seconds after the alarm goes off. However, once the alarm silences and the unit resets, the power comes back on. This is not the action required. It needs to stay off.
Only way I can think of doing it is to add another relay to make a latching circuit. Back to the drawing board.
Re: Yes, 3D printers can go on fire. January 28, 2014 05:00PM |
Re: Yes, 3D printers can go on fire. January 28, 2014 05:53PM |
TOmmm wrote
You can get relays that latch, and stay in the 'on' or 'off' state even after the coil has energised or de-energised... such as [uk.farnell.com], datasheet here [www.farnell.com]
a double winding latch relay has two coils - one for set, and one for reset. So no matter how many times your smoke alarm goes off or resets, your printer will stay off
Re: Yes, 3D printers can go on fire. January 28, 2014 10:14PM |
Re: Yes, 3D printers can go on fire. January 29, 2014 04:51AM |
Re: Yes, 3D printers can go on fire. January 29, 2014 09:32AM |
I can not find a thermal fuse rated to sustain temps over 230c. Most components on the printer are rated to make heat, the likelihood of a fuse catching it is slim. Any other things?
Re: Yes, 3D printers can go on fire. January 29, 2014 11:35AM |
Re: Yes, 3D printers can go on fire. January 29, 2014 03:16PM |
umdpru
That's why I measured right at the junction of the PEEK and the heater block. Under normal (my normal) operations, my printer prints at 230C registered on the thermistor. That temperature doesn't mean much when it comes to the thermal fusing. I measured the junction and it measures at approximately 165C. I will probably get a thermal fuse rated for 180C holding. My goal is to prevent a fire. I don't necessarily care about a J-head melting down so long as nothing around the printer is damaged. I'm looking for protection against catastrophe. So, on my machine, the point at which I measured the temperature is 165, if it rises another 15, then the thermal fuse should cut out the power in my design and save me from catastrophe.
Ultimately, I'd like to sacrifice a J-head for true peace of mind. In otherwords, do some practical testing and bring the temps up to melt to see at just what temperature, in my setup, they begin to melt to ensure the setup works but that will have to wait until I have a few hundred bucks burning a hole in my pocket.
In response to an earlier comments
You don't need a thermal fuse rated for the temperature of the hotend. You only need one rated for the location that it's in. In my case, the location that I will be placing it in very close to the hot end but still cool enough to use off the shelf components and prevent catastrophe (FIRE).
Re: Yes, 3D printers can go on fire. January 29, 2014 05:30PM |
