Re: Atfer Hbot, go to CoreXY. June 04, 2014 06:05PM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 01:01AM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 06:08AM |
zelogik
...Speed set to 100mm/s MAX. (yes marlin don't have double and quad step :-( ).
>?Quote
Ed Nisley's Blog
Marlin Firmware: Stepper Inerrupt timing
Marlin Firmware: Stepper Interrupt Timing
...a closer look at the step pulses as the motion starts from zero on the way to 150 mm/s:
hardwarekiller
MAX Stepperrate 63,7kHz ( je höher desdo besser ) nix 30khz, oder 48 khz da kommt werder Repetier Sprinter noch Teacup mit !
Marlin blässt von allen Firmware die ich bisher kenne UND getestet habe was die Stepprate UND die Laufruhe betrifft alle in GRUND und BODEN
Stepimpuls nur 3.5 µsec !
Schritfrequenz 63,7kHz !!
Damit steht fest Marlin ist WEITAUS schneller !
(sry again german)[sourceforge.net]Quote
And ramps with arduino mega.
Re: Atfer Hbot, go to CoreXY. June 05, 2014 06:12AM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 06:22AM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 09:01AM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 09:42AM |
Reinhold
IMHO all of the above doesn't really/nearly "explain" anything zelogik sees
(with his motors "1 infill line missing" (out of "3") should be quite a few steps ... much more than 4 (quadstep) too )
hope I didn't bore y'all - got 2 run
Regards
Reinhold
Re: Atfer Hbot, go to CoreXY. June 05, 2014 03:40PM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 03:51PM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 03:52PM |
Re: Atfer Hbot, go to CoreXY. June 05, 2014 03:53PM |
zelogik
Need to try to rotate file to 45°, i will restart slic3r as cura don't rotate infill :-)
Re: Atfer Hbot, go to CoreXY. June 05, 2014 03:57PM |
Re: Atfer Hbot, go to CoreXY. June 06, 2014 06:50AM |
Re: Atfer Hbot, go to CoreXY. June 07, 2014 02:18PM |
Re: Atfer Hbot, go to CoreXY. June 07, 2014 03:45PM |
Re: Atfer Hbot, go to CoreXY. June 07, 2014 03:53PM |
zelogik
...So it's backlash. It's not gt2, it's not bearing, it's Iglidur problem...
maybe look at:
Re: Atfer Hbot, go to CoreXY. June 07, 2014 04:05PM |
). Finally when I compare between lm8uu and Igus, both have gap and don't like moment.|
Re: Atfer Hbot, go to CoreXY. June 07, 2014 04:23PM |
zelogik
I need to make a brain-compute phase to find why Y and not X with a CoreXY setup ...
that's OK (with me)
Re: Atfer Hbot, go to CoreXY. June 08, 2014 03:04PM |
Re: Atfer Hbot, go to CoreXY. June 08, 2014 03:15PM |
Re: Atfer Hbot, go to CoreXY. June 08, 2014 05:19PM |
Re: Atfer Hbot, go to CoreXY. June 08, 2014 06:27PM |
Dejay
fabtotum uses a two level CoreXY belt path[/url].
"How to make cost cut engineering look good"
Re: Atfer Hbot, go to CoreXY. June 08, 2014 10:47PM |
zelogik
@dejay: the reason with the 4 more pulley are wrote on the previous page :-) to resume, it's for easier belt alignement and easier belt tightening.
Reinhold
!NOPE! NO corexy - that honor belongs to Ilan Moyer!Quote
Dejay
YOU might want to read the whole thread here.
Re: Atfer Hbot, go to CoreXY. June 09, 2014 04:33PM |
) a printer with a really large print volume. Something like a 600 to 1000mm cube print volume. And it should be able to carry a dual direct extruder, or rather a quad extruder that can directly feed something like the kraken but with only 2 steppers.|
Re: Atfer Hbot, go to CoreXY. June 09, 2014 04:45PM |
Dejay
Sorry for going a bit off topic here, I hope you won't mind
I'd like to build (or actually I would like to have) a printer with a really large print volume. Something like a 600 to 1000mm cube print volume. And it should be able to carry a dual direct extruder, or rather a quad extruder that can directly feed something like the kraken but with only 2 steppers.
Is there a coreXY design that uses aluminium extrusion with a wheel carriage for linear motion instead of heavy stainless steel rods? I figure aluminium extrusions would be inherently less prone to bend compared to rods and would have less weight. Basically like the delta / kossel mini wheel carriages that also run on extrusions.
This would reduce the weight of the moving carriage so that less force is needed for acceleration and might let you get away with the usual nema17 stepper motors, or at least use normal stepper drivers to drive nema23 motors (current limit).
As I understand coreXY it applies the forces in a way that would allow a kind of wheeled carriage, while hbot would probably not.
Aluminium extrusions won't be as precise as steel rods so you might need to calibrate bed leveling, but this might be a good idea anyway because of the large print bed will also be prone to not be as even or have slope.
Alternatively you could of course you could just use round hollow aluminium tubes, polish them and use them for the x axis and keep with steel rods for the y axis, since they don't contribute to the moving weight. This would even keep the current zelogik design.
Of course there would still be problems with heating a large print bed.
Would this be a sensible approach and what problems would you see with this?
Re: Atfer Hbot, go to CoreXY. June 09, 2014 06:59PM |
tkole
I made a corexy machine out of vslot aluminum extrusion and vslot wheels. It runs very smooth with no appreciable flexing of the extrusions. The problem I am facing is with my extruder/hotend. I can't come up with an extruder design that can match the mechanical capability of the printer.
Re: Atfer Hbot, go to CoreXY. June 09, 2014 07:01PM |
Re: Atfer Hbot, go to CoreXY. June 09, 2014 08:16PM |
Re: Atfer Hbot, go to CoreXY. June 09, 2014 09:23PM |
Re: Atfer Hbot, go to CoreXY. June 09, 2014 09:29PM |
