Re: Atfer Hbot, go to CoreXY.
January 24, 2016 03:14PM
Hello,
My name is Marcelo, I´m from Brazil.
I did download Jand STL files and need know What is the scale of the aluminium structure?
Someone help me?
January 25, 2016 02:59PM
The alu profiles are 20x20 mm.
The total dimension of the cube is 400x400x400 mm
January 25, 2016 03:09PM
gforce1
This is correct, but it means the horizontal profiles are 360 mm long and the vertical 400 mm
Maybe it is a good idea to have a look at the assembly file: RepRap-XY.step in the step folder in github: [github.com]
January 25, 2016 03:20PM
jand
gforce1
Thank you for help!
January 27, 2016 04:28PM
Hi Guys,
What size of the straps of the x-axis and Y and width of them? Should I use pulleys GT2 with 20 teeth?
February 26, 2016 07:03AM
Hi
Edited 1 time(s). Last edit at 02/26/2016 07:05AM by wendychai80.
February 26, 2016 07:04AM
jand
gforce1
Hi
where do you put endstop for x and y axis?
February 26, 2016 03:00PM
I have mounted the min-endstop for the x-axis on the leftside off the x-carrigae.
The y-min endstop is mounted on the front on the left hand side y-smooth-rod.
Home position is on the front left off the heatbed.
February 26, 2016 11:16PM
gforce1
Thanks for reply, im not yet start printing all the files yet and just starting ordering some parts yesterday.
I really like this design cause all the parts is inside the frame. Do you already complete building your machine?
February 27, 2016 06:49AM
Yes, i have build one. Made a few changes fot a nicer belt configuration.
February 27, 2016 07:11AM
Any picture or video winking smiley
Right now i'm still browsing for nema 17
February 27, 2016 03:49PM
These are older pictures.The cabling is all done now.
February 27, 2016 10:55PM
gforce1
Cool, blue look nice, do you use pla or abs for all the printed parts? any modification after complete the build?
February 28, 2016 07:48AM
It is all printed with ABS. No modifications were made after the completion.
I am now designing a new one with a 300x300 heatbed and 300 mm in the z-direction, two(or three)belt driven leadscrews, linear guides,Dual extruder(chimera).Outher dimensions will be 500x500x500 mm.
February 28, 2016 07:58AM
gforce1
Nice, any thread that i can follow your build?
February 28, 2016 08:07AM
No not yet. It is still on the drawing table..
February 28, 2016 08:15AM
oh ok, i already start the printing the files winking smiley can't wait for all the parts to come
February 28, 2016 02:05PM
wendychai80
gforce1
preview:
February 28, 2016 03:02PM
Have any of you shared your cad files at all? I'd like to build a custom version but it would be great to not stay from scratch as my cad ability is lacking right now.
February 28, 2016 03:36PM
You can find the originals here jand github
February 28, 2016 08:14PM
gforce1
Thank you!
February 28, 2016 10:11PM
gforce1
wendychai80
gforce1
preview:
The 2 motor above the spool is extruder motor?
And with the build you already complete now do you have any problem with only 1 z axis lead screw to move the bed?
March 05, 2016 01:01PM
wendychai80
Yes thats right
wendychai80
I do have sometimes problems with z-wobble. i have to straighten the z-screw to fix it. It is a M8 leadscrew,
March 08, 2016 11:01AM
gforce1,
Nice job.
How did you build the frame? Did you tap the ends or use L shaped brackets?
Are you happy with your choice?
Thanks.
March 08, 2016 03:17PM
3D_Printer_Guy
gforce1,
Nice job.
Thanks.
I tapped the ends like this. I am very happy with it. It is very sollid.
btw. the printer in the picture in the previous post has not been build yet.
This one is:
March 23, 2016 01:05AM
gforce1
3D_Printer_Guy
gforce1,
Nice job.
Thanks.
This one is:
Can i know the dimension aluminum profile that you use for the bed holder, on the file it was 3d printed, and do you change all the z axis printed parts to use the aluminum profile?
March 24, 2016 03:05PM
I used 2profiles 330mm long and 2 180mm long.
I only modified the nutholder to hold a m8 nut.
March 24, 2016 10:20PM
Thanks, im still waiting all my parts arrived before start building mine
April 05, 2016 09:59AM
My build so far https://www.youtube.com/watch?v=LHsid9rgR4o still waiting for other parts to come before i can start assemble all the frame together smiling bouncing smiley
June 05, 2016 07:46AM
I am working on a customised version of jands printer since some time.
Here are some pictures of the current status:
