Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 03, 2015 05:36PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 03, 2015 05:38PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 03, 2015 05:57PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 03, 2015 07:27PM |
patrickrio
2. After homing just X NEVER shows X=185, no matter what the start position.
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 03, 2015 08:59PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 04, 2015 03:17AM |
patrickrio
Wow, no need to apologize!!! I am very appreciative that you care enough to fix it.
Thanks for the work around... will DuetWebControl allow printing without homing???? I guess you wouldn't suggest it if it didn't....
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 04, 2015 02:12PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 04, 2015 02:36PM |
patrickrio
Hi, so I got the Zprobe working. However, when I hit Z home in DuetWebControl, it doesn't do anything. I assume there is standard, already written code for doing bed leveling and multiple point measurement with this probe. Can you direct me to that?
patrickrio
Also, my Z motor seems to drop power when it sits idle for a period of time, and this is allowing my bed to move. How do I keep the holding power up???
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 04, 2015 05:38PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 04, 2015 09:24PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 05, 2015 03:36AM |
patrickrio
Thanks,
New Firmware homes correctly.
patrickrio
However, G code print files that used to print now no longer wait for the printer to heat up and do not run the extruder....weird. it does all the movements with out heating up the print head and without extruding.... and it says that it keeps adding warm up time all the while it is moving around like it is printing.....Any Ideas????
patrickrio
Can you send me to a link that describes how to FTP files and/or firmware to the Duet for future reference???
patrickrio
Also, for Z axis homing, it starts from 260mm... so it goes REALLY slow for a long time to home......and the xy movement is also excruciatingly slow...any way to speed up????
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 06, 2015 01:11AM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 06, 2015 02:06AM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 06, 2015 11:59AM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 07, 2015 03:10AM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 07, 2015 10:19PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 08, 2015 10:21AM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 08, 2015 12:19PM |
patrickrio
Just to be clear, for a two extruder printer, the current inexpensive 32bit processor solution is the MKS SBASE. It's current version seems to have a design issue that causes 2-3 degree fluctuations of the hot end temperature though. It's current total price to the US is $55 delivered to the US.
I understand they will shortly release another version of this board that fixes the design issue, and that it will cost about $60. A $25 dollar Rasberry Pi would get me great connectivity and even give me the option of easily making it wirelessly connectable for another 6 dollars. This ends up being nearly half the price of the new Duet card for US delivery.
I really like how well the Duet card works though!!! it is really strait forward and the web interface is easy and no-nonsense. Frankly, it may be a better solution... BUT maybe not be double the price better.....
I will use the DUET for the single extruder printer I have now. IT WORKS GREAT!!!! and cost me $72 delivered to the US. This is the cheapest 32bit processor with internet connectivity option currently available. And with a dedicated CoreXY installation guide, it would be pretty plug and play.
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 08, 2015 01:06PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 08, 2015 01:48PM |
patrickrio
patrickrio
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 08, 2015 03:52PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 08, 2015 04:02PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 08, 2015 04:29PM |
patrickrio
I accidentally shorted the two wires to the proximity sensor that are connected on my machine to the top two end stop pins on the Duet Z axis (normally connected to the top two pins on the X axis).
The Duet went into a pretty hard crash. But more DANGEROUS is that this crash caused the hot end heater to turn on FULL BLAST even while the Duet itself was fully crashed. It got so hot that plastic started smoking and PEEK started melting.
The hot end was turned off before, so it wasn't like it just stayed turned on, the glitch CAUSED the hot end to turn on and did not resolve just by reset attempts or unplugging.
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 09, 2015 12:42AM |
patrickrio
In my opinion, The Duet needs a US supplier to be competitive here. It needs to get it's price for 5 drivers down to $95 shipped in the US to be considered, and down to $85 or less shipped to be truly competitive. I could probably suggest a good US distributor if they were interested and were committed to these prices.....
P
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 09, 2015 02:28AM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 09, 2015 05:10PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 10, 2015 02:39PM |
dc42
I've put a new RepRapFirmware.bin file at [dl.dropboxusercontent.com] which I believe fixes the XY homing issue. I've tested it as best as I can, using my Cartesian Ormerod to simulate a CoreXY machine.
I have also added support for simultaneous X and Y homing for CoreXY printers in this release. Once you are happy that X and Y home separately correctly, I'll tell you the changes you need to make to homeall.g for simultaneous XY homing.
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 20, 2015 06:04PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 20, 2015 07:25PM |
Re: Duet Controlled CoreXY - latest Firmware and Install Proceedure? August 21, 2015 11:06AM |
