Re: looking to build new printer, what sliding mechanisms should i use? September 20, 2015 02:36PM |
bradleyk
i did think about using that or a similar design, but thought the ballscrew would give better results.
i might need to have a look at building a test one using that design.
RichRap has done that aswell. but he used a geared stepper. here
Re: looking to build new printer, what sliding mechanisms should i use? September 20, 2015 11:34PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 21, 2015 07:50AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 21, 2015 09:33AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 21, 2015 11:49PM |
cristian
LarsK
Imagine if you put a stepper on that spectra wire and then you can just remove the ball screw completely. Never tried anything like it but would be really interesting. Ball screws are really what kicks the printer costs up.
I use some cheap spectra line for the Z axis of my smartrap: no wobble, almost zero cost, Z resolution of about 50 microns per full step. That is one problem that I solved completely, among thousands (that will be solved by a new printer).
Re: looking to build new printer, what sliding mechanisms should i use? September 22, 2015 11:47AM |
cozmicray
If the line wraps on itself the shaft radius changes -- changing Z lift per step
Since your talking microns overwrap is a lot?
You need to use a screw or winding mechanism to keep line flat?
Re: looking to build new printer, what sliding mechanisms should i use? September 23, 2015 11:52AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 23, 2015 01:36PM |
Re: looking to build new printer, what sliding mechanisms should i use? September 24, 2015 10:22AM |
Re: looking to build new printer, what sliding mechanisms should i use? September 24, 2015 02:48PM |
gmh39
Based on the drawing you posted, the carriage would move faster at the bottom of it's movement and slower at the top because the angle that the spectra line makes with vertical does not stay the same.
angle(X, Y) = arctan((D - X)/(H - Y)) = arctan(f(X, Y))where the angle is the one between the vertical shaft and the line. Consequently, the angle is constant if and only if f(X, Y) = (D - X)/(H - Y) stays constant. So let us see what happens to X and Y. An infinitely small change of X depends linearly on the change of Y and the current angle. If we suppose to work where tan(angle) is invertible, we have
dX = tan(angle(X, Y)) dY = tan(arctan(f(X, Y))) dY = f(X, Y) dYHere we actually see the differential equation (please, guess by yourself the symbol of partial derivatives that I don't know how to write here). For the (total) differential of f(X, Y) we have in general
d f(X, Y) = - dX / (H - Y) + (D - X) dY / (H - Y)2 = - f(X, Y) dY / (H - Y) + (D - X) dY / (H - Y)2 = - f(X, Y) dY / (H - Y) + f(X, Y) dY / (H - Y) = 0If I did not make mistakes, the differential of f (and consequently of the angle) is actually zero everywhere, which means it does not change if you roll the wire. Therefore, if you unroll a wire that was correctly rolled in the first place, the angle should never change.
gmh39
Granted, if you're printer is small enough and the "horizontal gap" is small enough, then the effect may be negligible, but that does not mean it does not exist.
Re: looking to build new printer, what sliding mechanisms should i use? September 30, 2015 09:14PM |
Re: looking to build new printer, what sliding mechanisms should i use? October 17, 2015 10:19PM |
Re: looking to build new printer, what sliding mechanisms should i use? November 01, 2015 05:36PM |
