Re: Best Z-axis configuration? November 19, 2015 08:54AM |
Edvardas
filipeCampos
Only speaking of the mechanism to move the bed and not the bed structure or linear motion. AndreasL is an interesting concept but i still think the use of lead screw is better.
One lead screw of 40cm has cost me 18€ on ebay and more 2€ for the coupler. If you go to the AndreasL solution it will be really cheaper? You still need to buy the belt, pulley and bearings. The total can be less of 20€.. but it really worth it? You still need to solve to problem of the missing reduction, something you automatically have in an lead screw solution. The belt allow fast speed, but you need this type of speed in the z axis?
I think there is better way to save money...
If a belt would be used on a cantilevered bed then it is a very simple design with few parts like on an original smartrapcore.
I think that belt on a Z-axis would be more forgiving to any design flaws. Screws need to be mounted just right or they cause trouble. Now if I want to use two screws I would need leadscrews with machined ends in order to fit them between bearings at both ends. I would still need pulleys and just right lenght close ended belt to run these screws of a single motor. Thats is quite a complicated mechanism. TR16x4 mechined-end leadscrew with a nut costs 30 euros for a set off dold-mechatronics.
Here is some information on the correct mounting techniques for leadscrews [blog.helixlinear.com] You can mount a single leadscrew according to A technique but to be able to use two screws driven off a single motor one would need use technique B. For this one would need a high quality perfectly straight lead screw otherwise screw would transmit any irreguliarities to the bed and to the print itself.
Re: Best Z-axis configuration? November 19, 2015 09:12AM |
filipeCampos
Modify the setup to have a good reduction and then it will be a great system.
Re: Best Z-axis configuration? November 19, 2015 09:22AM |
filipeCampos
I agree with you, if you do not have a rigid frame lead screw can be difficult to setup correctly and can not be the best option. This belt system appears to be a lot more forgiving. I was using was example the setup i have, i only use one lead screw.
But the missing reduction of the belt system is a deal break to me, i think you need to somehow add a least an reduction of 1:4.
You will have several possible problems because you are using an low reduction. it will be necessary to put a good amount of ampere in the motor, this will produce more heat. When printing, the motor need to always have current. After the print you must send an command to lower down the bed before cutting the motor power, this is not the default configuration you have in the sliders. If you update or change of slider and forget to change the default ending gcode you can have an bad surprise at the end of the print. I normally use the gcode command to cut off the power of the motor to change filament or only to move the carriage, with this setup you must be careful before using the functionality.
Re: Best Z-axis configuration? November 19, 2015 09:24AM |
LarsK
filipeCampos
Using a geared stepper will give you all those things. Will hold when powered off, very high reduction and low power use - Still very reasonable costs.
2:1 using belts is the limit I think. If you want 4:1 or more then you need to apply real gears... Thus geared stepper.
Re: Best Z-axis configuration? November 19, 2015 09:41AM |
Re: Best Z-axis configuration? November 19, 2015 09:49AM |
LarsK
Edvardas
Geared steppers are supposed to have backlash, no? Although sli3der 3d printer use geared stepper with a great results.
Only a problem if you move the bed up and down doing print. If you just go down ( one direction) the backlash should be irellevant.
Re: Best Z-axis configuration? November 19, 2015 12:08PM |
Technicaly, a lead screw is a pivot point, you can triangulate 1 screw and 2 guides, but you will have a big overhang.Quote
filipeCampos
Sadly, the hoist system of the smartrap cannot be use, because the two carriages would be independant, that's not what we want.Quote
realthor
The original smartrap has a different size (larger) upper pulley that acts as a reduction as I read somewhere. Can't that solution be applied for AndreasL's solution as well?
@J-Max: you don't want to use micro-stepping? Even a modest 4x or 8x would get you to the desired resolution.
With a 1:4 reduction you can reach 0,05mm per full step. Most 3d printers can't reach that Z resolution.Quote
Edvardas
I think that 4:1 reduction via pulleys would be complicated to achieve. Better do 2:1 belt reduction (40T and 20T pulleys) and use 400 steps per revolution stepper motor. That would be more compact and easier to source parts.
I awnsered about micro-stepping earlyer. The Z0 is set upon Zmin and is repeatable.Quote
Edvardas
What microstepping is used on Z-axis? What is the problem with current 0.2mm per step setup? Is Z0 easy to set and repeatable?
I could redesign AndreasL design on solidworks to be used for 2020 profiles and make it all beefier. I would also use 624 bearings for idlers as its size is almost the same as 20T GT2 pulley. Or do you know an European supplier of GT2 idler pulleys? Actually on AndreasL design only one idler pulley would be needed as the rest of idlers run on non-toothed side of belt.
Re: Best Z-axis configuration? November 19, 2015 01:54PM |
LarsK
- A 2:1 reduction can be made by passing the belt around a set of pulleys. That can look like this
Re: Best Z-axis configuration? November 19, 2015 03:44PM |
realthor
It should be pretty easy to add a second pulley on the motor side of the belt-Z design. I can see two improvements right away:
1) the double pulley will provide 2:1 reduction;
2) both pulleys can be 32 or 64 teeth pulleys and the motor one can be 16 teeth this will provide either another 2:1 or a 4:1 on top of the 2:1 provided by the compound pulley.
Hence a 4:1 or 8:1 reduction. That will throw you in the <0.05 per full step resolution for Z, with no microstepping.
The added benefit from turning the belt over and up is more contact
Re: Best Z-axis configuration? November 19, 2015 03:56PM |
Re: Best Z-axis configuration? November 20, 2015 06:17AM |
J-Max
Edvardas
The bed level is set manualy so you've got the right distance anywhere on the bed.
I thought 20T pulley's pitch was 12.73mm, so there's no perfect match for 20T (between 604 and 624).
On the version I'm working on, I used 16T pulleys (smaller diameter = better torque) and use 2xF623ZZ bearings are idler pulleys.
We can get perfect idler pulleys but its more expensive than bearings. And bearings works just fine.
They're pretty close to the GT2 16T (0.1mm delta in radius) and it's mostly a constant pitch diameter. For the tooth side of the belt, I use regular GT2 pulleys between MF105ZZ bearings.
++JM
Re: Best Z-axis configuration? November 20, 2015 09:02AM |
Resolution for the Z axis is only about layer height. Why would you like to offset first layer ?Quote
Edvardas
But you do not have an adjustable bolt that touches an endstop at Z0? It is used (on both my prusa i3 and corexy) to alter a distance between a nozzle and a bed without having to touch the leveling screws. And it is quite handy as different materials like different distances between a nozzle and a bed for the first layer.
To use it one needs a very high resolution on Z axis which is achievable only with leadscrews and not the belts.
Re: Best Z-axis configuration? November 21, 2015 07:38PM |
Re: Best Z-axis configuration? November 23, 2015 11:48AM |
realthor
Maybe we could use both belt and spectra for what they are good at. Belt for motion transmission from the motor and spectra for easy routing through a system of pulleys.
@LarsK: Could your design be multiplied laterally (with spectra that is) so that the achieved reduction could be much higher?
Re: Best Z-axis configuration? November 23, 2015 12:35PM |
LarsK
realthor
Technologically we (as in mankind - general industry) abandoned this kind of gearing many years ago in favor of gear boxes - And these days we move towards direct drives. Compound systems only remain widely in use on cranes. And on those they are just used because it is inconvenient to handle steel cables with the kind of diameter required otherwise.
Crane doing heavy kiln shell lift
I am not sure how to handle the gearbox backlash, yet I feel fairly confident in saying that more power should be found in either gears or bigger motors, not wrapped belts or lines. Even I am looking towards removing the 2:1 used on my CoreXY's.
Re: Best Z-axis configuration? November 23, 2015 01:03PM |
realthor
LarsK
realthor
Fair enough, I agree completely. My only grievance is that we can't do much with printing reliable gearboxes, as the plastic parts are very prone to plastic deformation and quick wear resulting in an ever increasing backlash that can't be linearly compensated for in software. And we will add yet another vitamin to the less and less replicable components. This might not be an issue with most reprappers though.
Re: Best Z-axis configuration? November 23, 2015 03:23PM |
Re: Best Z-axis configuration? November 23, 2015 03:25PM |
Re: Best Z-axis configuration? November 23, 2015 05:16PM |
J-Max
Hi guys,
Did you ever tryed the Igus Tribo filament ?
In many ways it seems better than nylon to me.
++JM
Re: Best Z-axis configuration? November 24, 2015 03:11AM |
Re: Best Z-axis configuration? November 24, 2015 06:32AM |
Re: Best Z-axis configuration? November 24, 2015 03:50PM |
Re: Best Z-axis configuration? December 05, 2015 05:32AM |
Re: Best Z-axis configuration? December 05, 2015 05:48AM |
Re: Best Z-axis configuration? December 06, 2015 10:23AM |
realthor
This is very interesting for two reasons: 1) I like the compound pulley that doubles the resolution and 2) I would have never thought that this solution would not bind.
There is also something that I don't quite like and that is the height of the slider, which is the same as it was if it were the usual on side lift. I would have thought that if you support the bed from 3 points you would be able to only use on single linear bearing on each rod so that you could gain some more Z height.
Nevertheless thanks for pointing me to it, it's a good concept to study.
Re: Best Z-axis configuration? December 06, 2015 11:21AM |
Re: Best Z-axis configuration? December 06, 2015 12:42PM |
fabrice974
no
if power go off, the bed still drop
if you don't have reliable electricity, you can use an inverter / ups
Re: Best Z-axis configuration? December 06, 2015 01:13PM |
Re: Best Z-axis configuration? December 06, 2015 01:42PM |
Re: Best Z-axis configuration? December 07, 2015 04:01PM |
