Re: CoreXYNZ build July 15, 2016 04:42PM |
Re: CoreXYNZ build July 15, 2016 08:29PM |
Cheers thanks for that. I wish I had asked earlier as I have already ordered a couple of 12" squares of 1/4". We have a waterjet at work which I occasionally operate (as little as possible they are dead boring) . I have agonised over the build plate for a while now. My current machine uses 6mm toughened glass which isn't very flat. I also have a piece of borosilicate glass coming, hopefully in one piece. I have a sheet of Printbite from Mutley3D as well.Quote
hobbymods
You can get cast plate from Calm Aluminium in Oz, and they've got a waterjet cutting guy just up the road from them that they work with.
Re: CoreXYNZ build July 16, 2016 08:59AM |
Re: CoreXYNZ build July 17, 2016 09:06PM |
Re: CoreXYNZ build July 17, 2016 11:04PM |
RodF
Working on the Z axis today. My original plan was to drive it with a single Nema 23 at 3A with a 2M542 stepper driver. Step and direction was going to come from the Smoothie board I got. However I also like the option of the new Duet Wifi so that's on preorder. I'm going to use the Smoothie to upgrade my current printer. My plan now is to use 2 Nema 17's on Z. Because they are in the same belt system any step discrepancy will be eliminated on shut down. The Duet drivers look better than the 2M542 apart from being current limited to 2A. Has anyone any ideas about the choice between 1.8 and 0.9 degree steppers in this application? The main downside of using 2 drivers on Z is that I am limited to 1 extruder. I was only going to use 1 extruder but it made me think about dual extruders. Yes it would be nice to print parts with rigid and flexible elements and also parts with dissolvable support structures. However I am OK without these at the moment. I am thinking of easily replaceable extruder heads though.
[attachment 81458 Zbase.png]
Re: CoreXYNZ build July 17, 2016 11:13PM |
Re: CoreXYNZ build July 18, 2016 01:04AM |
Re: CoreXYNZ build July 18, 2016 04:38AM |
RodF
I'm doing the same thing right now, but with a single Nema 17 stepper. And a different belt path just so I can fit my power supply and mother board in there as well.
Why would you need 2?
Wouldn't one be sufficient and simpler?
Re: CoreXYNZ build July 20, 2016 01:55AM |
Re: CoreXYNZ build July 20, 2016 05:19AM |
Re: CoreXYNZ build July 20, 2016 04:33PM |
filipeCampos
For the Z using 2 motors can be a problem because of synchronizations problems between the two and it will not allow to move the bed manually without "breaking" the bed level. The best is to try to find a solution with only one motor. In your case main problem is to be sure the motor was enouthg power to move correctly the bed, on thing you can do is to go with z screws that have a low pitch, like 1.5mm for example.
One remark abut the two linear rail of the bed, it will not be better to have them on opposite side?
where you will buy/get the closed belt of the motor bed?
On your 3d model you have lots of empty space on the top of your aluminium structure, why is the reason?
about the titan extruder and the tiny motor i curious to see if it will work well, do not forget to report later the result in this tread.
Re: CoreXYNZ build July 20, 2016 09:19PM |
Re: CoreXYNZ build July 24, 2016 05:45PM |
Re: CoreXYNZ build July 25, 2016 01:54AM |
Re: CoreXYNZ build July 27, 2016 10:58PM |
Re: CoreXYNZ build July 31, 2016 04:34PM |
Re: CoreXYNZ build July 31, 2016 10:06PM |
Re: CoreXYNZ build July 31, 2016 11:00PM |
Re: CoreXYNZ build August 01, 2016 01:35AM |
Re: CoreXYNZ build August 01, 2016 02:49AM |
Re: CoreXYNZ build August 01, 2016 04:26PM |
Re: CoreXYNZ build August 02, 2016 01:01AM |
Re: CoreXYNZ build August 03, 2016 08:02AM |
Re: CoreXYNZ build August 03, 2016 04:16PM |
Re: CoreXYNZ build August 03, 2016 07:54PM |
I need to cut it in half as I will upgrade my old printer which will also get a 220v heater and the smoothie board. 3mm T nuts and 20mm corners also arrived.|
Re: CoreXYNZ build August 03, 2016 10:51PM |
Thanks. Talking about looks I am going to try and get my vinyl cutter (600mm wide) involved. As this machine will be enclosed from the start the options for vinyl on the clear panels are wide open.Quote
hobbymods
Looks great!
Re: CoreXYNZ build August 04, 2016 04:52AM |
Re: CoreXYNZ build August 04, 2016 09:42PM |
Re: CoreXYNZ build August 04, 2016 10:09PM |
