Moving Gantry CoreXY Printer February 18, 2019 06:40PM |
Re: Moving Gantry CoreXY Printer February 19, 2019 07:51AM |
Re: Moving Gantry CoreXY Printer February 20, 2019 01:23AM |
Re: Moving Gantry CoreXY Printer February 20, 2019 03:16AM |
Re: Moving Gantry CoreXY Printer February 20, 2019 06:40AM |
Re: Moving Gantry CoreXY Printer February 20, 2019 09:37AM |
Re: Moving Gantry CoreXY Printer February 20, 2019 11:45AM |
Re: Moving Gantry CoreXY Printer February 20, 2019 12:34PM |
Re: Moving Gantry CoreXY Printer February 20, 2019 06:37PM |
Re: Moving Gantry CoreXY Printer February 20, 2019 08:13PM |
cozmicray
EcoSlide?
What is it?
Where?
Cost?
Re: Moving Gantry CoreXY Printer February 21, 2019 01:42AM |
Re: Moving Gantry CoreXY Printer February 21, 2019 02:17AM |
Re: Moving Gantry CoreXY Printer February 21, 2019 03:55PM |
dc42
Are you certain that your gantry will be rigid enough to need only 3 leadscrews to support it and not 4?
The Duet can level 4 leadscrews (assuming there is a little flexibility in the gantry) as well as 3.
Re: Moving Gantry CoreXY Printer February 21, 2019 04:02PM |
MKSA
What makes the ExoSlide different from regular wheel carriages ? The fact they are modular and can be assembled ? How do you adjust the "play", by the two long screws one can see ?
Re: Moving Gantry CoreXY Printer July 24, 2019 01:29AM |
Re: Moving Gantry CoreXY Printer July 24, 2019 02:05AM |
gmedlicott
Right now its running on Marlin 1.1.9 on a board with 5 drivers. I would like to move a board with 6 drivers (or ideally 7) for auto gantry leveling.
Re: Moving Gantry CoreXY Printer July 24, 2019 02:19AM |
You want to look at Klipper. with 1 additional 8 bit board and RPI you will have 10 stepper drivers, with 1 more board 15. So you can run 4 Z motors to auto-level and several more left for tool changer and a robotic arm to remove printed parts (this is optionalQuote
gmedlicott
Re: Moving Gantry CoreXY Printer July 24, 2019 11:12PM |
dc42
gmedlicott
Duet Maestro with daughter board provides 7 drivers (TMC2224, similar to TMC2208)
Duet WiFi or Duet Ethernet plus DueX2 provides 7 TMC2660 drivers, or 10 using DueX5 instead of DueX2.
All run RepRapFirmware which supports 2, 3 and 4 leadscrew true bed levelling as standard.
piper3d
gmedlicott
You want to look at Klipper. with 1 additional 8 bit board and RPI you will have 10 stepper drivers, with 1 more board 15. So you can run 4 Z motors to auto-level and several more left for tool changer and a robotic arm to remove printed parts (this is optional smiling smiley)
Re: Moving Gantry CoreXY Printer July 25, 2019 01:28AM |
Re: Moving Gantry CoreXY Printer July 25, 2019 01:51AM |
Re: Moving Gantry CoreXY Printer July 29, 2019 07:28AM |
Re: Moving Gantry CoreXY Printer July 29, 2019 08:49AM |
Re: Moving Gantry CoreXY Printer July 30, 2019 12:27AM |
the_digital_dentist
I don't think I've ever seen anyone position a lead screw out of parallel with a guide rail, but for some reason, people seem to think it's OK to do that with belts.
Re: Moving Gantry CoreXY Printer July 30, 2019 01:42AM |
Re: Moving Gantry CoreXY Printer July 30, 2019 02:41AM |
Re: Moving Gantry CoreXY Printer July 31, 2019 01:47PM |
MKSA
@gmedlicott
Can you detail why you now use 4 leadscrews driven by two steppers ?
Re: Moving Gantry CoreXY Printer September 24, 2019 03:34PM |
Re: Moving Gantry CoreXY Printer March 02, 2020 04:13AM |
Re: Moving Gantry CoreXY Printer March 02, 2020 04:25AM |
Re: Moving Gantry CoreXY Printer October 30, 2020 09:33AM |
adamfilip
This looks very similar to my Machine I call TitanXY that I made 3 years ago
check this out
[openbuilds.com]
[attachment 112767 titan2.PNG]
[attachment 112768 titan1.PNG]
Also, did you mount the gantry in a flexible way?
