Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch October 09, 2020 08:35PM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch October 12, 2020 03:58PM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch November 03, 2020 08:46AM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch November 03, 2020 02:05PM |
Recoil1980
Sorry I am just getting back around to responding.
I eventually sent the printer back. I think the sensor was just bad, then the LCD screen went white and I was unable to use it at all. I spend the extra money and got an Ender 5 Plus. So far the new one is running, but there are still a few issues with it.
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch February 10, 2021 08:31AM |
dlc60
No big. I figured it out.
I have never liked the inductive sensors and this one is no different. I have modified my X5SA Pro and am happy with it.
Removed bed sensor
Added borosilicate glass bed
Added Z-stop sensor
Lined the two Z steppers with a belt, so they never go out of sync
Removed stock hot end and replaced it with a E3Dv6 and modified fan duct
Boosted the acceleration and jerk specs to speed up the printer
The filament out detector failed a couple of months from when I turned the printer on. So I disabled that in firmware too.
Now the printer is consistent and reliable. It isn't an awesome printer, but it is pretty decent for $400 (plus the new hot end). And a 330x330mm bed is quite useful.
DLC
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch April 01, 2021 09:36PM |
dlc60
Recoil1980
Removed bed sensor
Added Z-stop sensor
DLC
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch April 08, 2021 12:38PM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch April 24, 2021 07:08PM |
lenigma1
dlc60
Recoil1980
Removed bed sensor
Added Z-stop sensor
DLC
I too am interested on how you achieved this.
However, I am on Marlin 2.0 firmware, and no more hotends-into-bed ever since!
BPD
M8083 I0; disable auto-leveling, I now use the Z min limit switch. M8500; Save the changes, you MUST use this line.
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch April 30, 2021 02:04PM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch April 30, 2021 07:38PM |
panch47
I just wanted to share my experience, I have changed the firmware with marlin and it works very well !
I have installed a direct drive and kept the proximity sensor with autoleveling. It's wonderfull how it works, no more nozzle in the bed
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch May 06, 2021 04:29PM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch July 05, 2021 07:40AM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch December 06, 2021 10:14AM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch April 08, 2022 05:58AM |
I got it for the 500-2E, as far as I know, they are suitable. Write to me, if it still actual or probably someone else will want itQuote
Yeti988
Late to dinner on this one, but does anyone have a good configuration.h file for a X5SA(this)? Running a V6 2 extractor board. The config in BugFix2.0 is for a different size and I don't know enough to figure the differences calculating the sizes.
I do know that the V6 has to run the "maple" environment not the regular Chitu103 or whatever it is.
I fought the process for 2 days but finally got the right combination to get it to compile, but it is way off. But it's on there....
Thanks in advance
Guido988
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch September 03, 2022 11:54PM |
dlc60
lenigma1
dlc60
Recoil1980
Removed bed sensor
Added Z-stop sensor
DLC
BPD
Sorry for the long delay - In case you haven't already figured this out.
You cannot use the same connector for the Z stop as you use for the inductive sensor. You have to go to the main board for that connector. When looking at the board you you can read the silkscreen designators, in the upper right corner (of my board at least) is a connector labeled Z-stop. My X5SA came with another end stop switch. You mount that switch on the plate where you mounted the Y-stop switch, in the obvious way. Look at how the other end stop switches are wired and wire you cable to match. You only need ground and signal, you don't need power. Connect you cable to that connector on the main board and run a new code script that disables the leveling firmware. For example:
Store this code on your micro-SD card as "disableautolevel.gcode".
Run the code by using the Print menu. After the printer beeps and throws up a message window that makes no sense, hit "OK" and power the printer off (make sure it beeps when it shuts off) and then back on. You are then set up to use the Z-stop. Test it by telling the printer to home Z and click the switch with your finger - don't risk a bed collision by assuming you did it all correctly the first time.
Be well,
DLC
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch September 04, 2022 01:41PM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch September 04, 2022 09:36PM |
But how do I load this into tronxy, I tried one by printing it and it did just that, went through the motion of printing. OK yes a stupid question, just read it is not a flashable file. So where can I get one. aon switch off I see no message or signal. I mentioned above that the firmware I have is V1.32 which is a Marlin.. Just a thought should I use M500 insread of M8500.|
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch September 05, 2022 07:32PM |
erniehatt
Thank you my Friend.
I must say you put a lot of work into that file, But I have a question, probably a stupid one in many an eyeBut how do I load this into tronxy, I tried one by printing it and it did just that, went through the motion of printing. OK yes a stupid question, just read it is not a flashable file. So where can I get one. aon switch off I see no message or signal. I mentioned above that the firmware I have is V1.32 which is a Marlin..
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch September 06, 2022 12:35AM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch September 06, 2022 01:00AM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch September 30, 2022 04:03AM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch November 22, 2022 05:13PM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch November 24, 2022 01:55PM |
isitworksnow
dlc60
so to disable the sensor these 2 lines need putting on to a sd card like doing a update etc.
only ask as i have been having trouble like many others with the sensor.
and had to update firmware because it would not boot up correctly yesterday.
apart from it's small problems it is a great printer.
You will need to find the connector for the Z min switch on your controller. I can't help you with that since they seem to change controller boards more often than some people change socks. You can find it on the controller board by looking where the other limit switches plug onto your board, the Z min will be in that area.|
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch November 27, 2022 11:13AM |
Re: Tronxy X5SA Pro - Marlin settings, removing auto level sensor and adding limit switch November 27, 2022 03:33PM |
dlc60
isitworksnow
dlc60
Put the M8500 at the end of the config file you write.
You do not have to include every configuration command to change only one thing. You can run a small one to do a single change. I like to keep a backup of the pre-change command set so that I can back out a change if I need to. The instructions are further up this chain for how to get the current config file.
You then have to find a way to put a Z min limit switch on your system. I printed up some pieces to handle that and my X5SA came with an extra limit switch, which I used on my printer. Mount it next to the Y-min switch, there are holes there already to do that for a Z-min switch. Perfect, the correct wiring and all TronXY took care of that.You will need to find the connector for the Z min switch on your controller. I can't help you with that since they seem to change controller boards more often than some people change socks. You can find it on the controller board by looking where the other limit switches plug onto your board, the Z min will be in that area.
I think inductive sensors stink, only contact switches seem to work well in my experience. They must be really cheap since all the kit makers seem to include them.
be well,
DLC
