servo fight
Posted by DARCOM
servo fight
May 11, 2012 02:18PM
Hello, when i try to print a part and the extruder does a small curve in 3mm space. the servo sounds like it locks up for a split second. This is causing shifts in my print. Im sure there is a setting but im not sure of the terminology of where to look. If i change the deg of the object in the g-code i can change what servo does the lockup and witch angle the shift will occur. So i have ruled out hardware. I have also used sprinter and marlin for flashing my gen6 and i have used slicer and skeinforge for the g-code. i have yet to find the correct place to change a value to correct this. any help would be great. Thanks
Re: servo fight
May 11, 2012 04:57PM
This happens on this object only or all objects?
When was the last time you adjusted the potentiometers on you stepper drivers? Maybe something got bumped?
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
Re: servo fight
May 24, 2012 08:46PM
After doing much studying the error is in the g-code. the only way to fix this problem for me is set the perimeters mm/s to 18. but for prints that don't have small spaces i will use 30.
Re: servo fight
May 29, 2012 08:57PM
I figured out the fix for my shifting problem. in sprinter or marlin my default_acceleration was too high. i was able to lower it and it caused the steppers to stop skipping on tight vertices. now no more skips.
