Iteration 2 shaft couplers diameter
August 11, 2012 02:08PM
Hello,
I've just figured out that shaft couplers from prusa iteration 2 (these ones) are too large for 5mm motor shaft. When couplers are fully screwed the inner diameter is about 6-7mm.
So I'm wondering - how to attach Z-axis threaded rods to motor shafts? The only solution I see is to wrap motor shaft with some tape or heatshrink tube. Or there are some trick for this?
Thanks.
Re: Iteration 2 shaft couplers diameter
August 11, 2012 02:37PM
August 11, 2012 03:01PM
nophead, thanks! I will try this.
August 11, 2012 07:53PM
5mm hose makes the motor shaft nice a grippy
__________________________________________________________________________
Experimenting in 3D in New Zealand
August 11, 2012 08:05PM
I was too impatient to wait until I had the opportunity to buy some aquarium hose, so I used heat shrink tubing and it worked great. I needed three layers.
K
August 12, 2012 06:31AM
I've tried aquarium hose and it works great.
Thank you, guys.
September 01, 2012 03:40AM
i accidentally ordered motors with 4mm shafts instead of 5mm so i made a better truly symetrical coupler in autocad. obviously its a 4mm to 8mm but it would be very simple to modify it to any other size coupler needed. tell me what you guys think. i have attached the stl and autocad files, so that you can view and modify them to your liking.
open | download - 4mm to 8mm coupling side 2 low quality.stl (124.5 KB)
open | download - 4mm to 8mm coupling side 1 low quality.stl (124.5 KB)
open | download - 4mm to 8mm coupling side 2.ipt (511.5 KB)
open | download - 4mm to 8mm coupling side 1.ipt (466.5 KB)
September 01, 2012 04:44AM
aduy, I like your design.
But maybe you should increase a space for nut a bit, to be able to use lock nut here?
September 01, 2012 04:32PM
if you give me the specs for a lock nut i can do that, i actually was just using the nuts that came in the hardware kit i got from ultimachine.
September 02, 2012 03:18AM
I'm talking about something like this.
Lock nut usually fit very tight, so I thought it might be better to use it in your shaft couplers.
September 03, 2012 01:25AM
it should be able to fit a lock nut, just fine. its the same size as a regular nut just taller.
