Nylock nut assembling
Posted by letsburn00
November 13, 2008 04:43AM
As part of building the lasercut reprap Y axis idler I have to put on a nyloc bolt. I'm having some real difficulty getting it on(I know it not moving is basically the point). Anyone have any tips for getting it on but keeping it's locking effect later on?
Re: Nylock nut assembling
November 13, 2008 08:44AM
The trick I have used in the past is to get a bolt of the same size, put it in a vice.
Then clamp the nut in vice-grips ( locking pliers ) and get the thread started.
Once you have started a thread in the nylon you should be able to take it off and get it onto the idler.
November 14, 2008 02:39AM
It should just screw on (non nylon end first) if not there is some damage to the metal threads which should be visable test both parts with a known good nut & bolt.
Ian
[www.bitsfrombytes.com]
