Why are my circles ovals?
Posted by RILEE04
May 23, 2013 01:56AM
I have a reprappro Mendel and I'm useing pronterface and slic3r and it happens no matter where on the bed I print. Can anyone tell me where to start troubleshooting?
Re: Why are my circles ovals?
May 23, 2013 05:48AM
Are they oval in one direction more than the other?
Ovality is normally caused by the steps being of in the x or y direction.
What pulleys?
Ben
May 23, 2013 06:07AM
If the ovals have flats on them you have backlash in one of your axes.
May 23, 2013 01:30PM
Or if they are tilted to one side, the bed doesn't move perpendicular to the x axis.
Edited 1 time(s). Last edit at 05/23/2013 01:30PM by Ralf.
May 23, 2013 03:32PM
Here's a pic. Hope it you can see it.
open | download - image.jpg (59.5 KB)
May 23, 2013 03:38PM
Another pic
open | download - image.jpg (35.6 KB)
May 23, 2013 05:52PM
Thats a clear case of backlash. Whats happening is that the motor reverses and moves a fraction before the mechanism starts to move in the other direction.
Make sure that your belts are decently tensioned and that there is no play in the system. Make sure the drive pulleys are firlmy attached to the motor shaft, make sure that the belt isn't slipping at the clamp. If all else fails, the slicer can compensate for backlash to a degree but for best results you want to get the machine as close to perfect as possible, and use backlash compensation as little as possible if at all.
May 24, 2013 05:04AM
Are your squares square?
May 25, 2013 04:53AM
Tightened up the belt and works much better! Thanks guys smiling smiley
