Pronterface setting 200 deg default October 07, 2013 01:14AM |
Re: Pronterface setting 200 deg default October 07, 2013 02:42AM |
Re: Pronterface setting 200 deg default October 07, 2013 06:12AM |
Re: Pronterface setting 200 deg default October 07, 2013 05:22PM |
Re: Pronterface setting 200 deg default October 08, 2013 05:21PM |
Re: Pronterface setting 200 deg default October 09, 2013 02:51PM |
Re: Pronterface setting 200 deg default October 09, 2013 04:02PM |
Re: Pronterface setting 200 deg default October 10, 2013 02:44AM |
Re: Pronterface setting 200 deg default October 10, 2013 05:44AM |
Re: Pronterface setting 200 deg default October 10, 2013 09:27AM |
Re: Pronterface setting 200 deg default October 11, 2013 05:40AM |
Re: Pronterface setting 200 deg default November 28, 2013 03:06PM |
Re: Pronterface setting 200 deg default November 28, 2013 05:04PM |
Re: Pronterface setting 200 deg default November 28, 2013 05:31PM |
Re: Pronterface setting 200 deg default November 28, 2013 06:13PM |
Re: Pronterface setting 200 deg default May 30, 2014 10:10AM |
HarveyC
Another thought...
Pronterface stores its settings in a file called .pronsolerc, its a text file without an extension. If there is one in C:\User\{user} it uses that by default, but if this one is not present it will use one located in the same directory as the one that holds pronterface.exe. If both are prersent it uses the one in c:\user\{user} ( I got caught out by this recently!).
Might be worth having a look in both places and checking what they contain.
Harvey
Re: Pronterface setting 200 deg default June 03, 2014 10:25AM |
Re: Pronterface setting 200 deg default June 03, 2014 05:00PM |
Re: Pronterface setting 200 deg default June 03, 2014 11:10PM |
Re: Pronterface setting 200 deg default June 04, 2014 09:05PM |
Re: Pronterface setting 200 deg default February 02, 2015 02:23AM |
