need Ideas as not enough extrude from hotend January 01, 2014 07:35AM |
Re: need Ideas as not enough extrude from hotend January 01, 2014 10:11AM |
Re: need Ideas as not enough extrude from hotend January 01, 2014 12:51PM |
DaveS
210 sounds ridiculously hot for PLA, I print at 185/186.
Could this be a slicer problem? Are you using 1.75 or 3mm PLA ? What is it set to in slicer?
Usually I'd say, calibrate your extruder, but if you've done that, I'd measure your filament with a micrometer/caliper and put that in your slicer.
I'd check all your slicing settings are the same as the filament/nozzle and you've not got a high retract value.
(1.5-2.5mm as a start for retract with a bowden)
hope that helps a bit.
Re: need Ideas as not enough extrude from hotend January 01, 2014 02:38PM |
Re: need Ideas as not enough extrude from hotend January 01, 2014 05:06PM |
uncle_bob
Feed rates above 40 mm/sec will be tough to do with any 3mm extruder, let alone a Bowden. I would set a max in your firmware at or below that and move on.
1.75 mm PLA is a bit more common for a Bowden. You sort of feed a bit faster, but have less back pressure.
What are you using for a tube? How smooth is it? How clean is it? How tight is it?
What sort of hot end are you using? How well does it hold temperature?
How dry is your filament?
Re: need Ideas as not enough extrude from hotend January 02, 2014 07:54AM |
Re: need Ideas as not enough extrude from hotend January 02, 2014 06:02PM |
bytemedwb
Do you have a fan on the top of your hot end?
From your description it sounds like the PLA is swelling in the hot end creating too much back pressure.
Also, it sounds like you calibrated without the hot end in place. I have always calculated with the
hot end on so that any minor slippage/back pressure is accounted for. But if you can't get it to
extrude consistently then it will be hard to calibrate.
