Printing ABS using Elmers glue on the bed January 13, 2014 04:36PM |
Re: Printing ABS using Elmers glue on the bed January 13, 2014 04:55PM |
Re: Printing ABS using Elmers glue on the bed January 14, 2014 08:27AM |
Re: Printing ABS using Elmers glue on the bed January 14, 2014 11:52AM |
Re: Printing ABS using Elmers glue on the bed January 14, 2014 03:03PM |
Re: Printing ABS using Elmers glue on the bed January 15, 2014 09:22PM |
Floyd
I use the purple glue stick for ABS at 110c with no issues. Ive only had one print lift off ever.
I also dont wipe and reapply every print, I just add more glue to the plate. I can normally get about 4 prints before I have to switch to my other sheet of glass and clean the other.
I REALLY dont want to use ABS juice because of the chemicals and the smell.
Re: Printing ABS using Elmers glue on the bed January 16, 2014 07:01AM |
Re: Printing ABS using Elmers glue on the bed January 16, 2014 07:39AM |
Re: Printing ABS using Elmers glue on the bed January 16, 2014 02:42PM |
dave3d
ABS juice works well if it is used on top of Kapton tape, but this is hassle. Elmers glue is easy and cheap to use if I can get it to work. I am going to try Floyd's method but my printer is in bits again while I do yet another mod.
Re: Printing ABS using Elmers glue on the bed January 17, 2014 10:15AM |
dave3d
Acetone is not particularly toxic. It is produced naturally in the body after all. It is best to avoid breathing it in though.
For me, ABS juice did not work if applied directly on glass. The print didn't just lift in a corner, it completely dislodged even with the glass at 110 deg C.
Re: Printing ABS using Elmers glue on the bed January 17, 2014 10:16AM |
Re: Printing ABS using Elmers glue on the bed January 17, 2014 11:03AM |
MrBaz
tjb1
I find Aqua Net hairspray works very good with PLA and ABS, just cover the bed lightly before every print. Takes just a couple seconds and don't have to deal with brushes or tape.
But you have to worry about highly flammable sticky hairspray getting over everything....
Re: Printing ABS using Elmers glue on the bed January 17, 2014 11:49AM |
tjb1
MrBaz
tjb1
I've been spraying it on the beds with no covers on anything for almost a year now. I would think its safer how we use it rather than the fumes getting sucked up by a hair dryer.
I'd say acetone is more flammable than hairspray anyway.
Re: Printing ABS using Elmers glue on the bed January 17, 2014 12:43PM |
MrBaz
tjb1
MrBaz
tjb1
Actually, the aerosol in the hairspray is way more flammable and in larger quantities than what little acetone evaporates from me wiping some abs juice on a cold mirror.
How do you deal with all the buildup and over spray that gets everywhere? I wipe on abs juice and it easily scrapes off for easy disposal. I use less acetone applying the abs juice than a woman would spend cleaning her nails.
Re: Printing ABS using Elmers glue on the bed January 17, 2014 03:02PM |
Re: Printing ABS using Elmers glue on the bed January 17, 2014 03:17PM |
tjb1
MrBaz
tjb1
MrBaz
tjb1
I spray it on the bed, not everywhere else. I don't have any build up elsewhere.
Re: Printing ABS using Elmers glue on the bed January 19, 2014 02:44AM |
dave3d
Re: Printing ABS using Elmers glue on the bed January 19, 2014 05:54AM |
Re: Printing ABS using Elmers glue on the bed January 21, 2014 05:04AM |
