Best placement for heatbed thermistor? March 28, 2014 10:29AM |
Re: Best placement for heatbed thermistor? March 28, 2014 12:23PM |
Re: Best placement for heatbed thermistor? March 28, 2014 12:53PM |
Alright, according to the pictures the thermistor is going through the pcb hole. I will use Kaptontape to insulate the wires.Quote
DaveX
On the Mendel90, Nophead epoxies it to the bottom of the PCB: [reprap.org] and then insulates the leads with teflon tubing and high temp tape.
But if i insulate each wire with kaptontape and then tape them with kapton tape the wires should be fine right?Quote
DaveX
The thermistor won't melt at bed temperatures, but the wiring and insulation you choose could behave differently.
Alright so placing it in the hole to touch the glass and at the same time remove the glass after every print would not be a very good solution.Quote
DaveX
You want the thermistor thermally connected to the bed so you get a consistent, representative temperature. Loose in the hole may give different readings based on the looseness of the gap, which is something you can prevent with a solid placement.
Re: Best placement for heatbed thermistor? March 28, 2014 02:26PM |
Archelon
Thanks for your answer!
DaveX
DaveX
DaveX
So you would recommend kaptontape it to the bottomside of the PCB, and not stick it through the hole? Sure I will get the temperature of the PCB bottomside but the glass top side will probably be about the same temperature right? (:
thanks again!
Re: Best placement for heatbed thermistor? March 29, 2014 10:30PM |
Re: Best placement for heatbed thermistor? March 30, 2014 04:15AM |
Re: Best placement for heatbed thermistor? December 23, 2014 09:18AM |
Re: Best placement for heatbed thermistor? December 24, 2014 04:20PM |
