Endstops explantation March 29, 2014 10:29AM |
Re: Endstops explantation March 29, 2014 10:46AM |
Re: Endstops explantation March 29, 2014 10:53AM |
like I said you probably burned out your ramps board now after you get a new one it all depends on how you have it set up in the configuration h file in what firmware you using. Most firmware I think is set up so that you run normally closed switches between signal and negative.Quote
BikeRide
but how to connect that endstop? there are + - and signal cable
Re: Endstops explantation March 29, 2014 10:55AM |
Re: Endstops explantation March 29, 2014 11:05AM |
Re: Endstops explantation March 29, 2014 11:13AM |
Re: Endstops explantation March 29, 2014 02:00PM |
