What type of bed spring should I get? June 19, 2014 09:04PM |
Re: What type of bed spring should I get? June 21, 2014 12:35PM |
Re: What type of bed spring should I get? June 21, 2014 12:36PM |
Re: What type of bed spring should I get? June 21, 2014 05:24PM |
Re: What type of bed spring should I get? June 21, 2014 05:36PM |
Re: What type of bed spring should I get? June 23, 2014 05:25PM |
Re: What type of bed spring should I get? June 27, 2014 11:10AM |
Re: What type of bed spring should I get? June 30, 2014 10:04AM |
Re: What type of bed spring should I get? June 30, 2014 12:58PM |
Re: What type of bed spring should I get? June 30, 2014 05:01PM |
Re: What type of bed spring should I get? June 30, 2014 05:37PM |
Re: What type of bed spring should I get? June 30, 2014 08:18PM |
Re: What type of bed spring should I get? July 01, 2014 07:56AM |
3dkarma
The value of having springs is saving your bed if your hot end crashes into it. With springs = bed moves down and no damage done. Without springs = cracked glass / groove dug into the bed / damaged hot end. The end stop should stop the latter happening, but mistakes are known to happen.
Re: What type of bed spring should I get? July 01, 2014 08:40AM |
Re: What type of bed spring should I get? July 01, 2014 06:45PM |
tjb1
3dkarma
No, this concept is enirely wrong. TURN DOWN YOUR Z DRIVER, you do not require that power.
As the person said above, "the strongest you can find, and that fit around your bed screws! ". Now can you tell me why someone would suggest "the strongest you can find"?? Because the bed moves when attached with springs, it wobbles and floats...maybe not up and down, but side to side and forward and back. This is solved by using very strong springs which negate the point of using them.
If you want to make good prints hard mount your bed and turn down your Z axis, they require almost no power on a cartesian because the Z axis does almost nothing.
If you are just printing for fun, do whatever you want...I don't care. Springs are not the way forward, ask anyone with experience.
Re: What type of bed spring should I get? July 01, 2014 11:06PM |
tjb1
3dkarma
It shouldn't wobble and float if the mounting screws are secure and the right size for the holes in the bed. I've got 3mm screws, 3mm holes in the bed, and no lateral movement at all. There's some friction of the screws in the holes so the bed doesn't float up and down as smoothly as it could, but it doesn't need to. It just needs to be easily adjustable, and give enough if a Z disaster happens.
Re: What type of bed spring should I get? July 02, 2014 07:40AM |
3dkarma
tjb1
3dkarma
Calling it "entirely wrong" is a bit strong. It is a reasonable failsafe, especially for beginners. There are many examples of printer designs, created by people with experience, that use sprung beds. For example, Reprappro, one of the oldest in the business, uses sprung beds. Using strong springs doesn't negate their usefulness - the bed will still move before the hotend causes damage.
