Making M3 Nuts flush into a 3D printed parts: any tips and tricks?
Posted by DennyP
July 26, 2014 10:03PM
Hello all,
My name is Dennis and I'm a Reprapper in Sydney currently working on a Reprap Rostock build.
This is the first experience with 3D printed parts and I've realized it's a lot more harder than it is lol.
I'm currently inserting the M3 nuts into the nut holes, however they do not fit originally; so it looks like it's a finishing job for me to do!
After using a miniature flathead screwdriver for a considerable amount of time, I've managed to fit the nuts as following:
However, it's not completely flush with the plastic.
The following photo of the actual nuthole I've worked on using the screwdriver:
As you can see, it's definitely not the best.
Any seasoned pros that can give me techniques tips that would make it work for mewinking smiley
Cheers!
Dennis
Re: Making M3 Nuts flush into a 3D printed parts: any tips and tricks?
July 26, 2014 11:05PM
You can try this technique just be careful not to overdo it!
[www.youtube.com]
--E_Roth_3
July 26, 2014 11:18PM
THANKS E_Roth_3! That's exactly what I needed
July 27, 2014 04:20AM
You can also dip your printed part into boiling water for 10 secs then push in the nut.
July 28, 2014 12:33PM
I had some luck using a soldering iron to heat the nut, sinking it into the plastic.
I definitely wouldn't recommend screwing it in to get a tight fit, split some of my parts that way.
EDIT: Just saw the video. In my case I used the side of the iron rather than the tip (which looked like it might hit plastic on the otherside of the nut). Also, once the nut was hot enough, you could likely flip the object over to get it flush rather than continueing to play with the iron.
Edited 1 time(s). Last edit at 07/28/2014 12:36PM by Kurzaa.
July 28, 2014 04:41PM
For PLA, I poke a long screw through from the other side, screw the nut on a few turns, then heat the nut with a lighter for a few seconds and pull the screw until it sinks in.
July 28, 2014 07:13PM
+1 for soldering iron method.
