V-Slot is totally solid, reliable, and modular July 29, 2014 07:35PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 12:26PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 02:49PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 07:08PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 08:46PM |
MrDoctorDIV
The only problem that CoreXY overcomes is the rotating of the gantry?
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 08:56PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 08:59PM |
MrDoctorDIV
Polycarbonate wheels
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 09:03PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 09:20PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 09:41PM |
Re: V-Slot is totally solid, reliable, and modular July 31, 2014 09:59PM |
Re: V-Slot is totally solid, reliable, and modular August 01, 2014 04:44PM |
Re: V-Slot is totally solid, reliable, and modular August 05, 2014 07:42PM |
Re: V-Slot is totally solid, reliable, and modular August 06, 2014 01:36PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: V-Slot is totally solid, reliable, and modular August 06, 2014 02:06PM |
Re: V-Slot is totally solid, reliable, and modular August 06, 2014 08:01PM |
Re: V-Slot is totally solid, reliable, and modular August 07, 2014 12:41AM |
Re: V-Slot is totally solid, reliable, and modular August 07, 2014 07:14PM |
MrDoctorDIV
If you put a precision shim [1mm thick, same one included in the kit available separate at 25 cents/pc] between the two bearings inside the wheel, you can then tighten the wheel as much as you want and it will still roll at its smoothest. Otherwise, if you tighten them too much, which is hardly tight for what I want, they will have much increased friction, too much will stop all movement.
Re: V-Slot is totally solid, reliable, and modular August 07, 2014 11:13PM |
Re: V-Slot is totally solid, reliable, and modular August 08, 2014 05:59AM |
Re: V-Slot is totally solid, reliable, and modular August 09, 2014 07:31PM |
Re: V-Slot is totally solid, reliable, and modular August 09, 2014 10:08PM |
Re: V-Slot is totally solid, reliable, and modular August 09, 2014 10:55PM |
Re: V-Slot is totally solid, reliable, and modular September 12, 2014 05:01PM |
vreihen
several of mine are still "crunchy" when I turn them with any kind of tension on the nylock nut.....
Re: V-Slot is totally solid, reliable, and modular September 12, 2014 05:41PM |
stoof
Vreihen (and whoever else may apply),
could you elaborate on "crunchy?" I recently bought a set of v-slot and wheel kits to test it out to make a new large format printer for myself. I like the setup, but I'm hesitant to stick with them as linear rails because I'm not experiencing very smooth motion. As I move the carriage up and down the rails by hand it feels like the wheels are getting caught in a divot, causing the movement to be jumpy and uneven. I don't think this will fly under operating conditions, so I'm hoping its something defective or not assembled correctly. I need to spend a little more time playing with it to find out what it might be. It seems to get caught at regular intervals of one wheel rotation, so it's not something on the rail.
Has anybody else had this problem with the v-slot wheels?
Re: V-Slot is totally solid, reliable, and modular September 12, 2014 08:04PM |
Re: V-Slot is totally solid, reliable, and modular September 13, 2014 10:55AM |
stoof
Re: V-Slot is totally solid, reliable, and modular September 13, 2014 11:46AM |
Re: V-Slot is totally solid, reliable, and modular September 13, 2014 04:28PM |
vreihen
stoof
Some of my MINI V-slot wheels turn "crunchy" when assembled and torqued, sort of like they are lacking lubrication or have a speck or two of sand on the bearings. I have read other people complaining about the problem, which may be limited to one batch of the mini-V wheels. The problem doesn't seem to cause any problems on my delta printer, and there are no signs of flat-spotting on the wheels to hint that they were skidding on the extrusions.....
