Marlin Firmware and Panelolu2 Problems
October 28, 2014 12:11AM
First off, not an electrons guy, not a coding guy and not one for updating firmware. Second, this is probably the wrong forum, but it doesn`t look like people check the firmware forums much.
Now the problem i have is, i bought a Panelolu2 from Think3DPrint3D and there are no instructions. i have searched the web and found a blog that instructs me.
[blog.think3dprint3d.com]
I`m usually pretty good at following instruction but i can`t seem to get it to work. I have to use a modified Marlin and some other stuff and upload them, i do what it says and i get his message.
FORCE_INLINE void print(const String &s)
With this as the explaination i guess....
In file included from cardreader.cpp:1:
/Marlin.h:30:22: error: Arduino.h: No such file or directory
In file included from /Marlin.h:37,
MarlinSerial.h:150: error: expected ',' or '...' before '&' token
MarlinSerial.h:150: error: ISO C++ forbids declaration of 'String' with no type
MarlinSerial.h:169: error: expected ',' or '...' before '&' token
MarlinSerial.h:169: error: ISO C++ forbids declaration of 'String' with no type
/MarlinSerial.h: In member function 'void MarlinSerial::print(int)':
MarlinSerial.h:152: error: 's' was not declared in this scope
I have no idea what this means, i`m not a programmer.
I have moved everthing into the directories as instructed. Any help with this would be aprecciated! I will also try and answer any questions as best i can.
Adam
Re: Marlin Firmware and Panelolu2 Problems
October 29, 2014 05:43PM
Hi Adam
Which version of Marlin and Ardunio are you using?
Also can you confirm if Marlin compiles fine without the panelolu2 enabled in firmware?
Cheers
Tony
DuetWifi.: advanced 3d printing electronics
October 31, 2014 09:49AM
It was just an Arduino problem, I was using 1.0.6 instead of 0023. Didn't think it mattered, but all is good now.
October 31, 2014 10:55AM
That means your using an old version of Marlin. It might be worth getting the latest, depending on what modifications the Think3DPrint3D version has.
