if you have Marlin firmware loaded it will give you the expected Baud rate in the Configuration.H file
well Pronterface is connecting to something if you are getting anything coming back. the messages wont make any sense until you connect to the correct comport at the correct speed.
is it possible you are trying to connect to the wrong device? are you sure the arduino USB port or cable are still working ? (assuming it's an arduino)
