Temperatures do not update when Heatbed turns on January 03, 2015 11:19PM |
Re: Temperatures don't update when Heatbed turns on January 04, 2015 12:09AM |
Re: Temperatures don't update when Heatbed turns on January 04, 2015 09:41AM |
Re: Temperatures do not update when Heatbed turns on January 05, 2015 05:55PM |
Re: Temperatures do not update when Heatbed turns on January 05, 2015 06:34PM |
Re: Temperatures do not update when Heatbed turns on January 05, 2015 07:26PM |
Re: Temperatures do not update when Heatbed turns on January 06, 2015 02:41AM |
Re: Temperatures do not update when Heatbed turns on January 06, 2015 09:30AM |
Re: Temperatures do not update when Heatbed turns on January 06, 2015 10:08AM |
nick001
HI Garfield,
thank you very much for the reply.
The system we purchased is the Aurora Z605 Prusi I3.
We can not find out in the documentation what we have for the hot end element and Thermal Resister.
The Parts List does not indicate specifics on the Hot End, which is the reason we are having difficultly.
We are using setting 8 in Marlin Configuration.h for the hot bed and the readings are within a few degrees of what the Repeter Host software indicates the temperature is on the Hot Bed.
We also tried each of the settings by trial and error, heated the extruder and could not get any temperature to be close.
I will keep trying the 100KOhm settings and the one you indicated you have.
The Kit did come with a spare thermal resister that had the following text on the heat shrink VW-1 HFT (030/1.5)
Thank you for the help and I greatly appreciate talking with you
NIck
Re: Temperatures do not update when Heatbed turns on January 06, 2015 01:24PM |
Re: Temperatures do not update when Heatbed turns on January 08, 2015 12:06PM |
Re: Temperatures do not update when Heatbed turns on January 09, 2015 03:57PM |
Re: Temperatures do not update when Heatbed turns on January 27, 2015 10:02PM |
