Need help to make a Touch Screen LCD for reprap 3D Printers January 23, 2015 04:35AM |
I was thinking of making a Touch Screen LCD for Reprap 3D Printers can anyonne suggest me on this.
Re: Need help to make a Touch Screen LCD for reprap 3D Printers January 23, 2015 06:02AM |
Re: Need help to make a Touch Screen LCD for reprap 3D Printers January 23, 2015 06:12AM |
Re: Need help to make a Touch Screen LCD for reprap 3D Printers January 23, 2015 07:06AM |
Re: Need help to make a Touch Screen LCD for reprap 3D Printers January 23, 2015 07:10AM |
Re: Need help to make a Touch Screen LCD for reprap 3D Printers January 23, 2015 08:55AM |
//LCD and SD support //#define ULTRA_LCD //general LCD support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) //#define SDSUPPORT // Enable SD Card Support in Hardware Console //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SD_CHECK_AND_RETRY // Use CRC checks and retries on the SD communication //#define ENCODER_PULSES_PER_STEP 1 // Increase if you have a high resolution encoder //#define ENCODER_STEPS_PER_MENU_ITEM 5 // Set according to ENCODER_PULSES_PER_STEP or your liking //#define ULTIMAKERCONTROLLER //as available from the Ultimaker online store. //#define ULTIPANEL //the UltiPanel as on Thingiverse //#define LCD_FEEDBACK_FREQUENCY_HZ 1000 // this is the tone frequency the buzzer plays when on UI feedback. ie Screen Click //#define LCD_FEEDBACK_FREQUENCY_DURATION_MS 100 // the duration the buzzer plays the UI feedback sound. ie Screen Click // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org] //#define MAKRPANEL // The RepRapDiscount Smart Controller (white PCSo, AFAIK, there's no touchscreen impemented on Marlin. Marlin only uses/recognize lines-style menus. No graphic interface is possible and wanted because of arduino mega possibilites busy by printing operations, and no graphic interface is implemented. So, even if you're a hard core programmer, I'm affraid you cannot run that kind of screen by Marlin. That's why you need an external controler (kinda computer) with video abilities, able to run simulteaneously an OS that can use a touchscreen, and a graphic software (like repetier 4 ex) to control the printer through an interface port (USB, Bluetooth, whatever...). Arduino/Ramps couple cannot do that. Sorry for the teaching.// [reprap.org] //#define REPRAP_DISCOUNT_SMART_CONTROLLER // The GADGETS3D G3D LCD/SD Controller (blue PC
// [reprap.org] //#define G3D_PANEL // The RepRapDiscount FULL GRAPHIC Smart Controller (quadratic white PC
// [reprap.org] // // ==> REMEMBER TO INSTALL U8glib to your ARDUINO library folder: [code.google.com] //#define REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER // The RepRapWorld REPRAPWORLD_KEYPAD v1.1 // [reprapworld.com] //#define REPRAPWORLD_KEYPAD //#define REPRAPWORLD_KEYPAD_MOVE_STEP 10.0 // how much should be moved when a key is pressed, eg 10.0 means 10mm per click // The Elefu RA Board Control Panel // [www.elefu.com] // REMEMBER TO INSTALL LiquidCrystal_I2C.h in your ARUDINO library folder: [github.com] //#define RA_CONTROL_PANEL
Re: Need help to make a Touch Screen LCD for reprap 3D Printers January 23, 2015 09:39AM |
