Nozzle keeps blocking January 31, 2015 05:18PM |
Re: Nozzle keeps blocking February 01, 2015 12:37AM |
Re: Nozzle keeps blocking February 03, 2015 11:09AM |
Re: Nozzle keeps blocking February 03, 2015 03:34PM |
Re: Nozzle keeps blocking February 03, 2015 06:39PM |
Re: Nozzle keeps blocking February 06, 2015 08:27AM |
elwood127
All I can say is I'm running at 230 and 60 for pla, 240 and 100 for abs. Until I installed a fan above the extruder blowing on the filament were it enters i was melting the filament above the hot zone causing endless failures. Since installing the fan I'm getting awesome prints on my $400.00 Prusa i3 knockoff. Also, if you heat the hotend to 80c (for pla) and pull out the ftlament, it will take everything out right to the nozzle hole. Run a wire through the hole to check for clear, cut your filament end nice and square and reinsert. I used a 40x40x20 mm fan with a 100 ohm pot for adjustment. Hope this helps.
