Two slic3r controlled fans
March 30, 2015 04:57PM
I have Rambo board which has two PWM controlled outputs for two fans. I am using Marlin firmware and Slic3r Gcode generator. I have printed this bowden mount and attached two fans to it. Would it be possible to control the second fan using GCode instead of having it set to a fixed value without modifying Marlin firmware logic?
Re: Two slic3r controlled fans
April 02, 2015 04:47AM
These two are effectively a single fan. Just like the z-motors on a Prusa. I believe you should connect them in parallel to a single connector on the board so it controls both the same.
ShapeForger
April 02, 2015 08:25AM
Thanks for your answer, krakadu. However, I have already modified Marlin to suit my needs. The modification was rather simple - just had to add pin definition in pins.h and call to analogWrite() function in planner.cpp.
April 24, 2015 07:46PM
> Hakimo, can you describe a little what you did in pins.h and planner.cpp?
I use a rambo board and am trying to add an always on, 2nd fan to my set up. I have one already using FAN0 PIN #8. I want another which is always on for my e3d hotend. In pins.h for a rambo board, #301, in that section I see
#define FAN_PIN            8
would I simply add
#define FAN_PIN            6
(the fan pin i'd like to use for a secondary fan)?
Or would double definitions cause issues?
Then in planner.cpp I see:
#if FAN_PIN > -1
    if (FanSpeed != 0){
      analogWrite(FAN_PIN,FanSpeed); // If buffer is empty use current fan speed
#endif
  if((DISABLE_X) && (x_active == 0)) disable_x();
  if((DISABLE_Y) && (y_active == 0)) disable_y();
  if((DISABLE_Z) && (z_active == 0)) disable_z();
  if((DISABLE_E) && (e_active == 0)) {
    disable_e0();
    disable_e1();
    disable_e2();
#if FAN_PIN > -1
  if((FanSpeed == 0) && (fan_speed ==0)) {
    analogWrite(FAN_PIN, 0);
  if (FanSpeed != 0 && tail_fan_speed !=0) {
    analogWrite(FAN_PIN,tail_fan_speed);
#endif
Does that mean I don't need to add anything else?
Thanks for any help.
April 24, 2015 08:02PM
If you want an always on fan, you don't have to modify planner.cpp.
In pins.h file you have to define FAN2_PIN. Add the following to pins.h:
#define FAN2_PIN           6
below your motherboard definition (Rambo)
#if MOTHERBOARD == 301
#define KNOWN_BOARD
Do NOT redefine FAN_PIN. Leave it alone.
In Configuration_adv.h file find the following line
#define EXTRUDER_0_AUTO_FAN_PIN -1
and change it to
#define EXTRUDER_0_AUTO_FAN_PIN FAN2_PIN
Now you can set the extruder's temperature which causes the fan to turn on (#define EXTRUDER_AUTO_FAN_TEMPERATURE 50) and speed of the fan (#define EXTRUDER_AUTO_FAN_SPEED 255) (255 means the fan will be running at 100% speed).
Edited 1 time(s). Last edit at 04/24/2015 08:03PM by hakimio.
April 24, 2015 08:08PM
Thanks Hakimio,
Fast response! Unfortunately I don't have
I believe I must have an older version of the firmware. Marlin_15 is what the filename is. I have an Airwolf 3D XL.
Is updating the firmware to a newer one, like 1.0.2, which I believe does have this support, a reasonable idea? Do i have to worry about things in that firmware being different or incompatible with my board?
Sorry, total newb here smiling smiley
April 24, 2015 08:13PM
Did you check Configuration.h or Configuration_adv.h? It's pretty old setting which was there for a really long time. I am pretty sure even 1.0.0 had it.
April 24, 2015 08:21PM
Yep, I have attached the version which was supplied by Airwolf. It looks to be 1.0.0...maybe they hacked out parts that weren't "relevant" ?
I also downloaded 1.0.2 and do abviously see this line etc...
So is upgrading the sensible thing to do?
open | download - MARLIN_XL_15.zip (206.2 KB)
April 24, 2015 08:30PM
Yeah, I guess you'll have to upgrade. Just don't forget to copy printer settings from the old version.
April 24, 2015 08:34PM
Thanks Hakimio, I will try and merge my info from the ofl firmware into the new one.
Just so I know, I shouldn't be worried about therer being new features in the new firmware that would cause damage to the board or printer right?
As long as I get all the printer specific settings copied over, motor steppings, PID values etc. I should be OK right?
April 25, 2015 06:56AM
Yes, it should be ok.
April 27, 2015 02:36PM
As an update, I successfully updated the firmware from the unknown, possibky gimped, possibly pre 1.0 version supplied by Airwolf to the newest 1.0.3 version found on github. I diffed the files and pulled over all the differences such as motor voltages, XYZ inversions, enstop settings etc....though I forgot to pull over the commented out endstops so the first print failed. But after I fixed that everything was fine. I think I may need to adjust the motor stepper values on the X and Y due to some not perfectly straight vertical walls on the 20mm test cube. I read somewhere that someone experienced a similar situation after changing to a different head. Could the difference in weight of the print head cause such a discrepancy?
Thanks for your help Hakimio.
April 27, 2015 05:05PM
sventizzle
If you are thinking about changing X or Y axis stepper motor steps/mm, don't. X and Y axis steps/mm have to be set to the values you get from Prusa calculator or your printer's manufacturer sets for you. That's not something you can calibrate.
I don't think so. I would suggest to simply calibrate your extruder stepper motor steps/mm and extrusion multiplier in Slic3r.
sventizzle
You are welcome smiling smiley
