Folger Y End Stop Position April 17, 2015 01:07AM |
Re: Folger Y End Stop Position April 17, 2015 01:18AM |
Re: Folger Y End Stop Position April 17, 2015 01:31AM |
Re: Folger Y End Stop Position April 17, 2015 10:48PM |
Vanbot
Thanks Enzo. I'm deep into the Folger thread and used the Folger manuals for my build.
But what I'm particularly looking for is the way people have set up their Y end stops so that the microswitch contacts the bare bearing. This is obviously only going to be the case in kits where there was no linear bearing holders on the Y carriage which is the case with mine.
Re: Folger Y End Stop Position April 18, 2015 01:03AM |
enzo1027
[attachment 53079 images.jpg]Quote
Vanbot
Of course I couldn't find the picture I was looking for, so I found something similar and made a note in paint. It's not the same bracket obviously, but the mounting style is similar as far as it being vertical goes. Hope this helps! It won't actually contact the bearing, but instead hit roughly the corner of the print bed where your leveling spring is. You'll still maintain your 200mm of travel as well
Re: Folger Y End Stop Position April 18, 2015 08:44AM |
Re: Folger Y End Stop Position April 18, 2015 11:57AM |
Ecky
That mount shown above isn't in the kit.
Like I said in another thread Dan told me to mount it on the extra bit of threaded rod sticking out the back which I did but you should mount it on the power supply side of the frame where it won't get caught by the heated bed wires. Tilt to the side to go under the heated bed and it can be actuated by the heated bed support frame. I inverted the Y motor cable as well to get the motor homing in the correct direction. I have done a dry print but haven't extruded any material yet.
Re: Folger Y End Stop Position April 18, 2015 07:45PM |
