Is turning up the extrusion multiplier the same thing as turning up the extruder steps per unit? July 13, 2015 06:39AM |
Re: Is turning up the extrusion multiplier the same thing as turning up the extruder steps per unit? July 13, 2015 06:44AM |
Re: Is turning up the extrusion multiplier the same thing as turning up the extruder steps per unit? July 19, 2015 01:44AM |
Re: Is turning up the extrusion multiplier the same thing as turning up the extruder steps per unit? July 19, 2015 03:34AM |
appdev007
If you find that you have had one non zero value in the extrusion multiplier for ever, then I suggest updating your the E steps in your firmware to apply this. One thing I use this multiplier for is to conpensate for different brands of filiments having different viscosities at the same temprature. My firmware E steps are base on how Ultimachine filiment worked in my machine. I reccomend people drop the extra coin and buy Ulti for their printers first run. In my opnion, it performs the best and matches up with expectations. Don't mess around with junk filiment when trying to calibrate your printer. Once you have it dialed in on the good stuff, buy some cheap stuff and figure out how to run it on your printer.
Re: Is turning up the extrusion multiplier the same thing as turning up the extruder steps per unit? July 19, 2015 07:02AM |
Re: Is turning up the extrusion multiplier the same thing as turning up the extruder steps per unit? July 19, 2015 09:08AM |
o_lampe
appdev007
If you find that you have had one non zero value in the ........ figure out how to run it on your printer.
Is this advertising?
I´m sure the tip is worth reading, but naming a certain brand twice leaves a bad taste...
Lately there was a "witch hunt" going on here because of advertising.
-Olaf
Re: Is turning up the extrusion multiplier the same thing as turning up the extruder steps per unit? July 19, 2015 09:17AM |
the_digital_dentist
Do you suppose that appdev7's 300+ posts over the last two years have all been .....
