Kossel 2020 delta printer - auto Z probe tuning September 12, 2015 09:19PM |
Re: Kossel 2020 delta printer - auto Z probe tuning September 13, 2015 02:57AM |
Re: Kossel 2020 delta printer - auto Z probe tuning September 13, 2015 04:56PM |
Re: Kossel 2020 delta printer - auto Z probe tuning September 14, 2015 12:21AM |
djtrance2
Thanks for the link. This is very good procedure. However, there is one part that seems a bit difficult:
1- it seems we need to adjust for the tower endstops manually using the screws that fasten the endstops to the extrusion aluminium. I can see 0.3mm adjustments to be very difficult to do by hand, are there setinngs in the firmware to adjust those distances instead?
Re: Kossel 2020 delta printer - auto Z probe tuning September 14, 2015 11:46PM |
Re: Kossel 2020 delta printer - auto Z probe tuning September 20, 2015 11:23AM |
Re: Kossel 2020 delta printer - auto Z probe tuning September 20, 2015 09:01PM |
djtrance2
In this video, the Gcode command used is M665.
I am using the Kossel Mini firmware.
These commands (M665 and M666) don't seem to be in the command list in the MarlinMain.cpp. Any way I can add them or use other commands? Or perhaps use another firmware.
I've tried using that command as M665 z200 instead of the default 315mm that the head is over the print surface. I follow with m500 tosave the command in EEPROM. When doing g28, it seems to reset the zmax to 315mm. I dont feel the M665 command is affecting the calibration at all. Is there something I am doing wrong?
Should I be using M666 instead?
Re: Kossel 2020 delta printer - auto Z probe tuning September 21, 2015 02:50AM |
Re: Kossel 2020 delta printer - auto Z probe tuning September 21, 2015 11:11AM |
