Nozzle maintenance... September 13, 2015 10:43AM |
Re: Nozzle maintenance... September 13, 2015 01:06PM |
KillerDave
Hi Folks!
Ok, Here's my Printer....
Sunhokey i3 fitted with a E3d V6 hot end, 0.4mm nozzle.
a print cooling fan (I need to configure this as cooling from the start seems to upset the first layer)
a PCB MK2B Dual Power heatbed and a Borosilicate glass Plate.
I think I'm also going to change the X carriage for an aluminium one???
Here's my problem for today....
I started a print and all looked normal as I gazed in awe and wondered how it works out where to go next and then it started the 2nd layer and right away I noticed it wasn't laying any material down...
It did complete the first layer but it just stopped on the 2nd????
The extruder was running but it was banging like it was jammed... this normally happens but clears after a while.... I think it's clogging in the hot end???
Any ideas on what I can do???
What is the best way to clean a nozzle???
I'm going to get some more nozzles and maybe try running a 0.2mm???
Re: Nozzle maintenance... September 13, 2015 04:17PM |
Re: Nozzle maintenance... September 13, 2015 09:24PM |
Re: Nozzle maintenance... September 13, 2015 11:45PM |
Re: Nozzle maintenance... September 14, 2015 01:09AM |
Re: Nozzle maintenance... September 14, 2015 07:40AM |
Re: Nozzle maintenance... September 14, 2015 07:56AM |
Re: Nozzle maintenance... September 14, 2015 12:00PM |
Re: Nozzle maintenance... September 15, 2015 09:39AM |
I have both. Actualy I can't make any differenceQuote
SteveRoy
Is it a genuine E3D of a China knockoff?
Re: Nozzle maintenance... September 15, 2015 10:25AM |
Re: Nozzle maintenance... September 17, 2015 09:20AM |
Re: Nozzle maintenance... September 17, 2015 11:01AM |
J-Max
Instead of vegetable oil, you can consider a teflon tubing in the heat break :
++JM
Re: Nozzle maintenance... September 17, 2015 11:24AM |
Re: Nozzle maintenance... September 17, 2015 12:56PM |
Re: Nozzle maintenance... September 17, 2015 05:13PM |
J-Max
Hi again,
I print ABS @235°C and teflon does not matter.
Maybe if you print nylon or PETG ?
++JM
Re: Nozzle maintenance... December 17, 2015 04:27PM |
Re: Nozzle maintenance... January 13, 2016 07:59AM |
Re: Nozzle maintenance... January 13, 2016 11:58AM |
SpodFab
wfcook,
Your fix looks great, I want to do this with mine. How did you fixed the steel wool to the Dremel?
Re: Nozzle maintenance... January 14, 2016 10:31PM |
Koenig
I think PTFE is good up to 240°C, if you are going to print something hotter you need to go all metal.
Reference for the temperature: [e3d-online.com]
