I bought a kit from China (Delta HE3D). Horrible instructions! I finished putting the kit together and this is what I know
Repetier-host is able to connect to the printer. All motors are working (after I fixed the pins that were wrong from the manufacturer).
The stepper boards are all verified good and installed correct (no jumpers installed under them for now)
Repetier-host does connect to the printer, under the manual control:
I am able to turn on/off/control heater on extruder and fan
I am able to turn off/on/control bed heater
I am able to move filament advance motor forward/backwards fast and slow
Only one motor moves if I do the manual XYZ. It takes -110X before it does anything. After that it moves both directions.
On the Reprap LCD screen it says "endstops hit: Z" or "endstops hit: X"
It is not anywhere near the top nor is tripping any endstops
I took wires off the board going to the stops and it still stays "endstops hit: Z" or "endstops hit: X"
Whats going on and what do I need to do????? I am sooo lost with this thing
Edited 1 time(s). Last edit at 09/29/2015 10:16PM by Outie.
