Prusa i3 2nd fan ?
Posted by bianchi
Prusa i3 2nd fan ?
November 15, 2015 04:05AM
Guys,
Why does the second fan of my Prusa i3 never rotate ?
Where can I find the setting for it ?
Thanks
Re: Prusa i3 2nd fan ?
November 15, 2015 06:59PM
It depends on your configuration. If you have two part cooling fans, both can be connected in parallel to the fan controller pin. If it's for the fan on the hot end, connect it directly to a 12V psu, it should always be running.
Kind regards
Imqqmi
NFAN CoreXY printer:
[reprap.org]
November 15, 2015 09:09PM
I guess my part fan is broken I tested with battery and there's no response....and at the fan connector is 12.98V...I ll buy new fan...
What does part fan do?
November 16, 2015 04:20AM
Hi guys,
The part fan cools the filament as it just goes out of the nozzle.
So the fused filament stays in place. It's mostly usefull for overhangs, bridges, and small areas, like sharp ends (pyramid top alike).
++JM
