VDX
... you can try with sending G-code "G1 E50".
If it's set to absolute positioning, then "G91", "G1 E50", "G90" (or all three lines in a script) should do ...
*Looking at the photos*
Type the above into the box just below disconnected, it has the word g-code to left and send to right, when the manual control tab is selected.
enter a valid g-code into that box and click send, the printer will perform it as requested.
Here is list of valid g-codes and there function [
reprap.org]
Edited 1 time(s). Last edit at 02/04/2016 09:02AM by orictosh.
Supporting 3D Printers with Parts and Build services.
Printer: Ormerod 2 (528.4) Duel extruder set-up with Aluminium X-Rib, RRPro Firmware v1.11-ch (2016-04-08)
