PRUSA i3 Problems. February 19, 2016 07:50AM |
Re: PRUSA i3 Problems. February 19, 2016 09:30AM |
--- Configuration.h 2016-02-19 08:21:36.222016397 -0600 +++ ../../Marlin_clean/Marlin/Configuration.h 2016-01-20 19:44:05.126495886 -0600 @@ -48,7 +48,7 @@ // startup. Implementation of an idea by Prof Braino to inform user that any changes made to this // build by the user have been successfully uploaded into firmware. #define STRING_CONFIG_H_AUTHOR "(none, default config)" // Who made the changes. -//#define SHOW_BOOTSCREEN +#define SHOW_BOOTSCREEN #define STRING_SPLASH_LINE1 SHORT_BUILD_VERSION // will be shown during bootup in line 1 //#define STRING_SPLASH_LINE2 STRING_DISTRIBUTION_DATE // will be shown during bootup in line 2 @@ -62,7 +62,7 @@ // This determines the communication speed of the printer // :[2400,9600,19200,38400,57600,115200,250000] -#define BAUDRATE 115200 +#define BAUDRATE 250000 // Enable the Bluetooth serial interface on AT90USB devices //#define BLUETOOTH @@ -70,13 +70,12 @@ // The following define selects which electronics board you have. // Please choose the name from boards.h that matches your setup #ifndef MOTHERBOARD - #define MOTHERBOARD BOARD_ULTIMAKER - //#define MOTHERBOARD BOARD_RAMPS_14_EEB + #define MOTHERBOARD BOARD_RAMPS_13_EFB #endif // Optional custom name for your RepStrap or other custom machine // Displayed in the LCD "Ready" message -#define CUSTOM_MACHINE_NAME "I3 Pro B" +//#define CUSTOM_MACHINE_NAME "3D Printer" // Define this to set a unique identifier for this printer, (Used by some programs to differentiate between machines) // You can use an online service to generate a random UUID. (eg [www.uuidgenerator.net]) @@ -146,11 +145,11 @@ //#define DUMMY_THERMISTOR_998_VALUE 25 //#define DUMMY_THERMISTOR_999_VALUE 100 // :{ '0': "Not used", '4': "10k !! do not use for a hotend. Bad resolution at high temp. !!", '1': "100k / 4.7k - EPCOS", '51': "100k / 1k - EPCOS", '6': "100k / 4.7k EPCOS - Not as accurate as Table 1", '5': "100K / 4.7k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '7': "100k / 4.7k Honeywell 135-104LAG-J01", '71': "100k / 4.7k Honeywell 135-104LAF-J01", '8': "100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT", '9': "100k / 4.7k GE Sensing AL03006-58.2K-97-G1", '10': "100k / 4.7k RS 198-961", '11': "100k / 4.7k beta 3950 1%", '12': "100k / 4.7k 0603 SMD Vishay NTCS0603E3104FXT (calibrated for Makibox hot bed)", '13': "100k Hisens 3950 1% up to 300°C for hotend 'Simple ONE ' & hotend 'All In ONE'", '60': "100k Maker's Tool Works Kapton Bed Thermistor beta=3950", '55': "100k / 1k - ATC Semitec 104GT-2 (Used in ParCan & J-Head)", '2': "200k / 4.7k - ATC Semitec 204GT-2", '52': "200k / 1k - ATC Semitec 204GT-2", '-2': "Thermocouple + MAX6675 (only for sensor 0)", '-1': "Thermocouple + AD595", '3': "Mendel-parts / 4.7k", '1047': "Pt1000 / 4.7k", '1010': "Pt1000 / 1k (non standard)", '20': "PT100 (Ultimainboard V2.x)", '147': "Pt100 / 4.7k", '110': "Pt100 / 1k (non-standard)", '998': "Dummy 1", '999': "Dummy 2" } -#define TEMP_SENSOR_0 11 +#define TEMP_SENSOR_0 1 #define TEMP_SENSOR_1 0 #define TEMP_SENSOR_2 0 #define TEMP_SENSOR_3 0 -#define TEMP_SENSOR_BED 1 +#define TEMP_SENSOR_BED 0 // This makes temp sensor 1 a redundant sensor for sensor 0. If the temperatures difference between these sensors is to high the print will be aborted. //#define TEMP_SENSOR_1_AS_REDUNDANT @@ -210,9 +209,9 @@ // If you are using a pre-configured hotend then you can use one of the value sets by uncommenting it // Ultimaker - #define DEFAULT_Kp 14.27 - #define DEFAULT_Ki 0.61 - #define DEFAULT_Kd 83.82 + #define DEFAULT_Kp 22.2 + #define DEFAULT_Ki 1.08 + #define DEFAULT_Kd 114 // MakerGear //#define DEFAULT_Kp 7.0 @@ -238,7 +237,7 @@ // If your configuration is significantly different than this and you don't understand the issues involved, you probably // shouldn't use bed PID until someone else verifies your hardware works. // If this is enabled, find your own PID constants below. -#define PIDTEMPBED +//#define PIDTEMPBED //#define BED_LIMIT_SWITCHING @@ -256,9 +255,9 @@ //120v 250W silicone heater into 4mm borosilicate (MendelMax 1.5+) //from FOPDT model - kp=.39 Tp=405 Tdead=66, Tc set to 79.2, aggressive factor of .15 (vs .1, 1, 10) - #define DEFAULT_bedKp 496.03 - #define DEFAULT_bedKi 62.3 - #define DEFAULT_bedKd 987.42 + #define DEFAULT_bedKp 10.00 + #define DEFAULT_bedKi .023 + #define DEFAULT_bedKd 305.4 //120v 250W silicone heater into 4mm borosilicate (MendelMax 1.5+) //from pidautotune @@ -298,7 +297,7 @@ */ #define THERMAL_PROTECTION_HOTENDS // Enable thermal protection for all extruders -//#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed +#define THERMAL_PROTECTION_BED // Enable thermal protection for the heated bed //=========================================================================== //============================= Mechanical Settings ========================= @@ -376,7 +375,7 @@ // @section extruder // For direct drive extruder v9 set to true, for geared extruder set to false. -#define INVERT_E0_DIR true +#define INVERT_E0_DIR false #define INVERT_E1_DIR false #define INVERT_E2_DIR false #define INVERT_E3_DIR false @@ -399,9 +398,9 @@ #define X_MIN_POS 0 #define Y_MIN_POS 0 #define Z_MIN_POS 0 -#define X_MAX_POS 195 -#define Y_MAX_POS 195 -#define Z_MAX_POS 190 +#define X_MAX_POS 200 +#define Y_MAX_POS 200 +#define Z_MAX_POS 200 //=========================================================================== //========================= Filament Runout Sensor ========================== @@ -588,16 +587,16 @@ // default settings -#define DEFAULT_AXIS_STEPS_PER_UNIT {78.74,78.74,2560,211} // default steps per unit for Ultimaker -#define DEFAULT_MAX_FEEDRATE {400, 400, 30, 25} // (mm/sec) -#define DEFAULT_MAX_ACCELERATION {1400,1400,120,80000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. +#define DEFAULT_AXIS_STEPS_PER_UNIT {80,80,4000,500} // default steps per unit for Ultimaker +#define DEFAULT_MAX_FEEDRATE {300, 300, 5, 25} // (mm/sec) +#define DEFAULT_MAX_ACCELERATION {3000,3000,100,10000} // X, Y, Z, E maximum start speed for accelerated moves. E default values are good for Skeinforge 40+, for older versions raise them a lot. #define DEFAULT_ACCELERATION 3000 // X, Y, Z and E acceleration in mm/s^2 for printing moves #define DEFAULT_RETRACT_ACCELERATION 3000 // E acceleration in mm/s^2 for retracts #define DEFAULT_TRAVEL_ACCELERATION 3000 // X, Y, Z acceleration in mm/s^2 for travel (non printing) moves // The speed change that does not require acceleration (i.e. the software might assume it can be done instantaneously) -#define DEFAULT_XYJERK 30 // (mm/sec) +#define DEFAULT_XYJERK 20.0 // (mm/sec) #define DEFAULT_ZJERK 0.4 // (mm/sec) #define DEFAULT_EJERK 5.0 // (mm/sec) @@ -626,7 +625,7 @@ // M501 - reads parameters from EEPROM (if you need reset them after you changed them temporarily). // M502 - reverts to the default "factory settings". You still need to store them in EEPROM afterwards if you want to. //define this to enable EEPROM support -#define EEPROM_SETTINGS +//#define EEPROM_SETTINGS #if ENABLED(EEPROM_SETTINGS) // To disable EEPROM Serial responses and decrease program space by ~1700 byte: comment this out: @@ -666,7 +665,7 @@ //#define ULTRA_LCD //general LCD support, also 16x2 //#define DOGLCD // Support for SPI LCD 128x64 (Controller ST7565R graphic Display Family) -#define SDSUPPORT // Enable SD Card Support in Hardware Console +//#define SDSUPPORT // Enable SD Card Support in Hardware Console // Changed behaviour! If you need SDSUPPORT uncomment it! //#define SDSLOW // Use slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) //#define SDEXTRASLOW // Use even slower SD transfer mode (not normally needed - uncomment if you're getting volume init error) @@ -681,7 +680,7 @@ // 0 to disable buzzer feedback. Test with M300 S P // PanelOne from T3P3 (via RAMPS 1.4 AUX2/AUX3) // [reprap.org] -#define PANEL_ONE +//#define PANEL_ONE // The MaKr3d Makr-Panel with graphic controller and SD support // [reprap.org]
Re: PRUSA i3 Problems. February 19, 2016 10:25AM |
Re: PRUSA i3 Problems. February 19, 2016 03:14PM |
Re: PRUSA i3 Problems. February 19, 2016 03:21PM |
Re: PRUSA i3 Problems. February 19, 2016 04:17PM |
Re: PRUSA i3 Problems. February 19, 2016 09:24PM |
Re: PRUSA i3 Problems. February 20, 2016 06:12AM |
Re: PRUSA i3 Problems. February 20, 2016 06:50AM |
Re: PRUSA i3 Problems. February 20, 2016 01:12PM |
Re: PRUSA i3 Problems. February 20, 2016 04:01PM |
Re: PRUSA i3 Problems. February 20, 2016 07:06PM |
Re: PRUSA i3 Problems. February 20, 2016 08:03PM |
Re: PRUSA i3 Problems. March 05, 2016 11:16AM |
